Can anyone let me know if a CR 250 engine from
1998 CR 250, ill fit straight into a 3rd gen 2002-2007
CR 250
Or are there any mods to be
done
thanks in advance
CR 250
done
thanks in advance
Edited Date/Time:
CR 250
done
thanks in advance
https://www.ebay.com/itm/CR250-9607-FRAME-CONVERSION-RED-1992-2001-CR250-ENGINE-2002-2007-CR250-FRAME/252938204955?hash=item3ae44ab71b:g:qPQAAOSwHoFXu34p
I believe thats all you need
I have done it. This is my 2000 engine in my 06 frame. Very easy swap. You will need 00-01 radiators and hoses, pipe, upper motor mount, 00-01 air boot and I think that's about it. Shave the back of the engine where it is square to get shock spring clearance. It's extra material and is not on the 02-07 engines. The front lower motor mount needs to be shaved about 1/16th to fit the bolt through. You can't install the engine in the frame complete. You have to take the cylinder off and bolt the bottom end in first. Also it's tight clearance between the spark plug and gas tank. I heated the plastic up with a heat gun and made clearance but from what I understand there is a short version of the br8eg or whatever it is. Great bike overall! My favorite cr250.
