Mingo Junction, OH
I need to try to update the suspension on my restored
1990 Cr125, to something alittle more modern.
Does anyone know if I can use a set of forks and triple clamps up to 1997
to replace my stock pogo sticks ?
Thank you in advance .
Hi,
Ive just restored this 1990 CR 125,
And am also on my second one!
The one in pic has Pro-Flex rear shock
46.5 cm eye to eye, (46cm standard)
And later 98 WP front end originally
From a KX -250 98,
The bike sits higher and is actually just like a new bike in height due to the high seat foam also fitted.
The second 1990 I am building now
I am going to run
1989 conventional CR-125 forks that are
Modified by Pro-Flex, and said to be one of
The best options in the day.
Along with a pro-flex rear shock
46cm eye to eye (original size)
So second bike will sit lower!
Once both bikes are ready in a couple of weeks I can update the post
Bike in pic rides mint!
Lower clamp bearing is bigger in 1990
But you can put the 1990 lower bearing on to 1989 clamps
If you go newer then you will have to play with bearings etc,
But you can get nearly all front ends to fit,
As shown by my bike having a complete
98KX front in it
Post a reply to: 1990 CR125 , Need Suspension Help.
