1989 CR125 Jetting help
2/18/2020 6:41 PM
I recently restored the bike. Totally stock with the original bore. Only mod is Boyesen reeds.
Stock jets are 165 main and 60 pilot. Air screw 2.5 out. Needle - 3rd slot
I bought a service kit out of the UK with an OEM piston and rings and it came with a gang of jets.
Main - 170, 172, 178, 180
Pilot - 50, 55
Not even broke in it smokes like crazy and leaks out of the muffler. So I dropped a 172 main and 50 pilot.
Haven't started it yet as I am rebuilding the shock.
Any advice would be greatly appreciated. Its been years since I messed with jetting.
Thanks in advance!
-Robbie
2/18/2020 6:53 PM
2/20/2020 11:53 AM
Pro Circuit web site has jetting listed for these old2t”s. Search their site. I use it as base line for my old builds.
2/20/2020 11:55 AM
2/20/2020 1:04 PM
Edited Date/Time: 2/20/2020 1:04 PM
the stock jets should work fine. You said it smokes like crazy - not to lead you down a wrong path (because two strokes normally smoke some) but did you replace the right side crank seal?
2/21/2020 4:46 PM
Salient point, no I did not.
2/21/2020 4:57 PM
Weird thing it starts fine, right side isn't sucking air making it hard to start, fired right up.
I went through though that deal with my daughter's 86 jr 50 and it wouldn't start because if that issue.
2/22/2020 6:05 AM
I’ve seen, and had bikes start fine with bad right crank seals. They smoke like a train, and smell bad. If you replace the seal, replace the collar the seal slides over too.
2/22/2020 6:06 AM
Do you still have the old piston? Shoot a photo of the underside and post it on here.
2/22/2020 9:55 AM
2/22/2020 3:54 PM
Edited Date/Time: 2/22/2020 4:09 PM
Crap, I totally misread your statement. Yes I replaced that seal, I replaced every seal except the left side crank.
I have the seal, I should just buy a flywheel puller and replace it.
2/23/2020 2:50 PM
What kind of premix and ratio are you running, and what kind of riding? I ride woods and tight single track on my 88 CR125 which is essentially identical in the engine department, and have no issues. I’ve always run Maxima Castor 927 at 40:1. I don’t remember off the top of my head what my jetting is, but it’s pretty close to stock.
2/23/2020 3:22 PM
Well good thing you replaced that seal because the old one was definitely sucking some transmission oil. I’d say try PC’s jetting and see what happens.
2/23/2020 5:18 PM
Edited Date/Time: 2/23/2020 5:19 PM
Huge thanks to everyone who responded, it means a lot to be a part of this community. Your insights helped me greatly.
As anyone of you know, building a 30yr old bike with no records is like whack-a-mole.
You all rule.
2/23/2020 5:56 PM
For the record, that underside of the piston where the carbon was collected was the same side where the piston and ring showed blow by. Not sure I would blame it on a blown crank seal. If I am wrong, please clue me in.
2/23/2020 6:07 PM
It is not even broken in yet, running 927 32:1 like I have been forever. My plan on riding is just moto tracks on practice days.
