CRF250X Running Hot
1/10/2019 4:57 PM
I need some advice! I've got a 2006 250X that seems to run really hot when I get into any kind of soft terrain. I live in Southern Utah and we have a loft of soft stuff so it's not an option to just stay away from it. The motor is totally stock with only about 60 hours total on it. It has a yosh slip-on muffler and I have removed the backfire screen on the air filter. I am planning on having stainless steel valves put in it here very soon so while I have it apart I am going to swap over to engine ice or Evan's coolant and possibly do some small tweaks to help with the cooling. I want to keep the bike mostly stock just to keep the engine life up but the cooling is driving me crazy. I am planning on buying a YZ250X in the next year or two so I don't have to worry about the cooling on this bike as much but until then I need some suggestions. Thanks guys!
1/22/2019 10:24 PM
Put a fan on it, lm sure someone makes a fan kit.
1/23/2019 2:53 PM
I believe Honda did offer a fan kit have you seen if it is running lean as that causes hotter running
2/28/2019 6:43 PM
With the slip on, if it wasn't re-jetted it would be lean. Check your plug.
Fan and engine ice (already mentioned).
Do you over-rev? Try to be a gear higher when possible.
