Round Rock, TX
Hey y'all, looking for some experienced engine guys to give me an idea of what the heck is going on here. Truck is an 07 escalade ext with the 6.2L l92 that runs and stays perfectly at temp while engine is on. Coolant is filled to the cold fill line appropriately and using GM dexcool as is required by the manual. But for some weird reason, whenever it gets shut off after running for a bit the temps creep up and have gotten as high as 5/8's of the way to the max on the gauge. For a bit i thought my gauge was malfunctioning, till i realized that whenever i start the truck anywhere above operating temp i get a nasty knocking from the engine on startup. Should the fans be on more, thermostat malfunctioning, too low of pressure... anything? Really wracking my brain trying to figure out how it can stay at temp the entire time while running but creep whenever its shut off. Can give any extra info if yall have questions.. thanks!!
(water pump is driven off the engine so those electric fans that stay running as you walk away from the vehicle don't do as much as they could)
KMC- I think the T's had no water pumps, but they did have a fan at least. 22 hp and 4.5:1 compression doesn't exactly put a ton of heat in the cooling system though!
Post a reply to: Truck engine overheating AFTER being turned off?
