xr/crf 80/100 air filter straight to carb
Edited Date/Time 6/26/2018 5:27am
I have a 2006 crf80 pitbike that I would like to put a uni air filter straight to the carb without the airbox. I am wondering if anyone has done this or know's what uni filter I need to use, do I still use a crf80 air filter?
GoonSquad250x
Kennesaw , GA US
4018th
6/25/2018 7:11pm
Google says:
UNI 2-Stage Clamp-On Pod Air Filter For Honda XR80R, CRF80F, XR100R, CRF100F. $20.95 EBay
6/25/2018 7:14pm
Google says:
Is that for a standard airbox setup or is that straight to the carb
BobPA
PA US
6/25/2018 7:15pm
Pointless mod. Remove the choke plate if you want some free horsepower.
GoonSquad250x
Kennesaw , GA US
4018th
6/25/2018 7:17pm Edited Date/Time 6/25/2018 7:17pm
Google says:
Straight to it. My buddy did it to his XR100 when racing go cart tracks. Not sure how much it adds to it, but a lot of guys seem to do it.
Paw Paw 271
Benton, LA US
6/25/2018 7:24pm
You will find that this set up will reduce air flow.
BobPA
PA US
6/25/2018 7:27pm
How would you go about doing that
I removed it from my 100 in probably 2002. So it has been a bit haha. I believe you remove the two screws holding the choke plate to the shaft. Remove plate and slide out the choke shaft. Makes it a pain the in ass to start when it is very cold out...But frees up a bit of horsepower up top.
TeamGreen
Thru-out, CA US
6/25/2018 7:34pm
The stock system has well thought out plenum considerations.
Sachmo831
South Bend, IN US
6/26/2018 5:27am
On my xr100 I removed the snorkel piece on top of the airbox and cut it out larger, then covered it with steel screen to keep larger debris out. I also cut the muffler off and welded on an old 2 stroke silencer. Just doing these two mods made a noticable difference in power after rejetting.
Post a reply to: xr/crf 80/100 air filter straight to carb
