shock oil weight in a 2004 cr250 shock
9/7/2018 3:54 PM
I've looked everywhere and i can't find any info. Does anyone know the weight of shock oil that comes stock with this shock? Im looking to do a fluid change and can't find any info on this.
thanks
9/7/2018 4:32 PM
2.5 or equivalent
9/7/2018 5:27 PM
2004 CR250 Showa shock use's SS-7 5w showa suspension fluid or 5wt. equivalent.
9/7/2018 5:45 PM
have you tried race tech database. when you search for spring rates it also display wear parts and oils
9/7/2018 6:01 PM
You need an oil with a 'high viscosity index' , means it doesn't thin out too much when it gets hot. You want an oil with an ISO (lnternational Standards Organization) weight of 11.0 (Bel Ray HVI-3) or 15.0 (Ohlins shock oil).
All oils have an ISO rating, just go to their online 'data sheet', SAE 5w type ratings are old school and not exact.
Melbourne, Australia. Current rides: '11 RMZ450, '84 CR500, '06 DRZ400, '79 KX250 with 400 engine, '06 GSXR1000 full Yosh racebike.
9/7/2018 8:18 PM
I use KYB oils in all my motorcycles and never had an issue either Showa or KYB.
2020.5 KTM 450 SXF FE
2006 KX250
9/7/2018 10:41 PM
ATF
2 Stroke, Drum Brakes, Finned Cylinders!!!
9/7/2018 11:14 PM
ctbale wrote:
ATF
Welcome to 1973.
9/8/2018 5:57 AM
thanks guys, factory connection got back to me and and they said to use 2.5 in the stock shock
