- Pick trends
- Create a private league
- And more!
Next question, how do I do a squish test? Lol
It wouldn't hurt to call or email Eric Gorr.
I know I'm being dense here but what exactly am I measuring before and after?
I had to kinda reassemble one of the linkage needle bearings, which I just did, so now it's time to bolt everything else down, I think I'm good to go.. fingers crossed.
I ran some highly modified methanol fueled cr250 engines in micro sprints and I've ran as tight as .038 in certain situations .. I wouldn't go that tight obviously but Gore should tell you what to use with pump gas vs race gas etc..
Before Gorr the piston was flush with the top of the cylinder?
A dime is roughly .045 - .047 thick. If the thickness of your compressed solder is at least as thick as a dime, that is about the cheapest, easiest way to measure where you are at. Hopefully you got the solder near the edge of the bore / piston, when the engine was rolled over, and not in the center of the head.
Man, fuck dirtbikes.
The way the cylinder had been dropped so much is going to move the powerband notably lower.
Post a reply to: piston top clearing cyl top
