Yz 125 won’t shift
9/5/2019 12:08 PM
Edited Date/Time: 9/5/2019 12:14 PM
Hey all! My buddy has a 2000 yz125 that shifts but won’t engage. I’m not sure if it has to do with the shifting mechanism or the clutch. I can physically shift it through all the gears, and say if I shifted into 4th, I can roll the bike and it acts like it’s in neutral. Id like to get opinions from you all before I tear into it. Thanks!
9/5/2019 12:14 PM
9/5/2019 1:32 PM
Only one sure way to find out and that’s to take it apart.
Obviously start with the clutch since it’s only about a 15 minute job to take it out.
9/5/2019 2:46 PM
My sons RM85 did this ended up being only the selector fork smile cheap and easy fix. Best of luck with the yz smile
9/5/2019 3:02 PM
Thank y’all!
9/5/2019 4:05 PM
I know they updated the shift fork in 07. I was told to put this in my 06 so I wouldn't have problems
9/5/2019 4:07 PM
When's the last time you changed the clutch plates? Sure the clutch isn't slipping.
9/5/2019 4:17 PM
Edited Date/Time: 9/6/2019 2:15 AM
Clutch basket is broke I bet. I had two late 90’s yz crap out the baskets back then
9/5/2019 4:47 PM
Definitely clutch related. Easy fix. Replace all of the clutch parts while you’re in there. Will save you another tear down later on.
9/5/2019 8:12 PM
Anybody have...?
Anybody know...?
Much ty
9/5/2019 10:54 PM
They made the change in the 06 didn't they?
9/6/2019 5:08 AM
I think it was 07. I went thru several on my 2006
9/6/2019 5:16 AM
Good to know.I always thought they updated it on the 06.
9/6/2019 11:27 AM
Edited Date/Time: 9/6/2019 11:29 AM
If it’s shifting through the gears it’s most likely not a shift fork. But your title says “YZ 125 won’t shift”..... you can shift through the gears without using the clutch. If it’s shifting, but not engaging properly, its probably clutch related. You have to take apart the clutch first anyways to split the cases and get to the tranny.
