- Pick trends
- Create a private league
- And more!
Also just for reference, none of my stock maps for either the 18 or 21 are all zeros.
BTW...as mentioned above, my stock maps are all numbered and no zero's.
***correction*** if i wanted the stock map, i would make a new map, call it stock, leave it with zero’s.
You can change map to map without messing with the settings on the map. Just transfer the map to map 1 or map 2. When you upload it, it will replace the one for the other in the slot you want it.
Hope this helps,
Chad
It's been a few years, but I believe the Honda PGMfi programmer worked this way, in that the PCM had the base map as all zeros, and +/- cells were richer/leaner or retarded/advanced. The power tuner app seems to be a dumbed down version of that in that it has a LOT less resolution.
Post a reply to: Yamaha Power Tuner app
