White House, DC
Purchased an 18' YZ250F and absolutely love the the machine except for the front brake response..riding KTMs for the last few years I became spoiled with that feel. What is the best setup to get a better responsive front brake? I am a rider that relies on front stopping power much more than the rear and need a better responsive brake set up.
I went with brembo cylinder, 2.5mm motostuff steel line and braking 270mm rotor
Im sure the right one would work well.
- Motostuff 280mm rotor kit
- 2012+ Honda master cylinder
- Honda OE front brake pads
Basically the rotor swept area is designed to allow the use of Honda brake pads which provide a 30% increase in contact area providing less heat, less arm pump and longer life. The 2012+ Honda master cylinder has an 11mm bore compared to the 9.5mm bore of the Yamaha. In addition the slick ball and socket linkage keeps the lever action buttery smooth.
It is better than my other YZs (which have stock brakes plus a 270mm floating rotor).
In my opinion, the non-floating rotors like the ones from MotoStuff and Galfer have better feel than the floaters I've tried.
The Honda OE pads feel better to me, but they make a tiny bit more noise.
Those Honda pads won't fit the YZ caliper.
I THINK they are made by motion pro but not sure.
Post a reply to: YZ250F Front Brake
