Hello there everyone,
I have a yz250f 2016 fuel injection 4 stroke motocross bike, the bike is driving me insane as i have an issue with it.
The problem is, one minute the bike will start up and rev no problem at all will run great for as long as you keep it running, you then turn the bike off and it won't take a rev, will just bog out and back fire, after a lot off attempts of turning it of and starting it back up again you might get it to run sweet again, I have replaced the injector, had a full top end rebuild done and also sent the stator off for testing, Bike is still the same, i am reading a lot off people saying about TPS and wiring harnesses,
Could anyone point me in the right direction as it is an intermittent Fault,
How do i Check the TPS Sensor?
Any help would be much appreciated.
Many Thanks
Dennis
Many Thanks
Dennis
Working in a bike shop for years I have seen bad grounds, bad spark plug caps with too much resistance or arcing to the head, and wires shorting to ground also cause those kinds of issues.
Post a reply to: YZ250 Problems ANY HELP???
