Wisdom Needed: Please help determine which bike is right for me
Grouper
Paducah, KY US
Edited Date/Time 1/28/2022 8:58am
No banter. I have always ridden RM-Z250's until a collegiate hiatus and now that I am on a YZ250 2 stroke I just don't feel the comfort level that I traditionally felt. I have about 19 hours on it now and have had some great motos but I miss the advantages I felt with a four stroke
Current mods are 9 oz. flywheel weight, Honda master, braided line, .46 kg/mm fork springs, 5.8 kg/mm shock spring. Stock tires (MX52?).
I'm about 6'3 and weigh 200-210 lb. I race 250B and 250 open (if available).
Some things I do not like about the YZ250:
-Handling. This is 85% of the problem. This bike is allergic to cornering. I swapped to 22mm offset clamps from the stock 25, and now it just wants to oversteer. I am happy with the straight line stability and the way it hooks up under power, but I dread cornering. Anticipating the responses here, I cannot seem to get the bike to sag down to 105mm. There may be some fine tuning left to do, but I am confident there is not a fix-all hidden in the clickers.
-Engine Characteristic: I feel like there is such a small window of pull power. It is always revving out, or its out of the powerband and I'm needing to clutch it hardcore. No in between. There may be a fix (pipe, gearing, etc.), but I am not really interested in continuously dumping money into a bike.
-Jetting: Boy, I hate it. This thing runs alright, but it detonates more often than I'd like. I am not interested in running special fuels. I understand that this is easily fixed, but jetting is not a set and forget subject.
-Engine braking: Especially the Suzuki's I had, it just felt like the rear wheel was suctioned to the racing surface. I like to ride with the front and for the rear end to stay put. Typically with a fairly neutral body positioning.
-Power Linearity: Now that I don't live near sand based tracks anymore, I feel this a lot. One blip of the throttle on the two stroke and the whole bike is upset. This is somewhat of a restatement of the first point, but the yz250 feels like it is always on ice skates. It's only happy on tracks with softer, loamier surfaces where it pays to keep things a little looser.
Current Ideas (not in order)
Here's where I need the help..
-Pretty much any 250f from Honda, Kawi, Suz, or GASGAS. I do tend to think I'm a bit large for a 250f these days. I got tired of having to seat bounce everything on a 250f.
-RM-Z450: Obvious bias, but one thing that discourages this is that there is consensus on three big issues: suspension is hard to set up, engine is tailored for low to mid rpm use, and the new chassis is not as stable as times past. I ride in the upper half of the rpm range and a flat engine is such a hassle. I also think this is the heftiest financial investment due to poor resale.
-KX450: Seems to do everything well, except handle. Maybe I'm just buying a more expensive continued headache.
-MC350f: This is probably the most appealing choice, but I cannot find one, nor do I know much about the austrian bikes in general. The 350's are appealing because they do not have the excessive power that the big bikes do, but still have plenty of gusto.
I generally worry that a 450 is going to be "too much". I want to be able to ride aggressively without needing to ratchet strap myself to the bike. I also worry about the unforgiving nature bikes that powerful can have. I hope some fruitful discussion will ensue. Thanks for reading my book lol.
Also, I'll come back and add this. If you have the experience to make the claim that you think I just need to man up and spend some money on suspension and jet the bike, then take some lessons, then say it. I want a solution more than a new bike chat. I can learn how to get better with the rear brake if this bike could turn a little better.
motodad312
Mc Kinney, TX US
1/25/2022 10:28am
For what it's worth my son is 6'4'' and about 195 lbs. He's on a KTM 250 sxf and loves it. I caught your comment on riding the upper band of the rpm range. My son, if anything, always over-revved his other (Japanese brand) 250f's. Pretty hard to do on a KTM. Those bikes pull and thrive in the upper end of that rpm band.
Grouper
Paducah, KY US
1/25/2022 10:31am
motodad312 wrote:
For what it's worth my son is 6'4'' and about 195 lbs. He's on a KTM 250 sxf and loves it. I caught your comment on...
Good to know. I can remember so many days of finding my flow and just begging that 250 to go faster out of corners and having to double alot of jumps and so on. I'm not totally opposed, but thats why I listed the 350 as being the ideal (plausible) option.
I really would love to hop on about a half dozen bikes and then I could make the choice much more easily.
TheGetFresh
COOL GY
2773rd
1/25/2022 10:42am
If setup and rideability are your main targets, the YZ450 shouldn’t be overlooked. The chassis is great, suspension is best in class and won’t leave you hunting for settings so much, and the engine has a free feeling that let’s you coast into corners without too much engine breaking.
That said, it’s a strong motor. Not scary like the Hondas have been recently, but still strong. At your size, if you are physically strong and don’t get yourself into those “red mist” situations you should be able to keep it under control, but I wouldn’t blame you for opting for the 250f either way.
Grouper
Paducah, KY US
1/25/2022 10:50am
If setup and rideability are your main targets, the YZ450 shouldn’t be overlooked. The chassis is great, suspension is best in class and won’t leave you...
Really my deal with the 450's is that I tend to shine when I can push the bikes. I'm open to riding one but I also think I prefer to be on something with a little less power and I close the gap with my riding.
It is probably worth mentioning I have never in my life spun a single lap or even ridden a 450 around in the pits for some reason.
hylo
NO
1/25/2022 10:51am
I’m really not the right person to answer since I am very biased. I like KTMs. Alot.
I ride a 250 sx two stroke and have done so for a few years now. Jetting is not set and forget, but it isn’t that much of a hassle either IMO. I get you, I really do. You wanna spend time at the track riding, not jetting.
I’d say 350 all day long. Less tiresome than a 450, lively, fun and you can still race 450s with it without too much of a loss of power.
And you can still put a Ktm mapping switch on the Gas Gas to make use of the mapping and traction controll. Smile
austin_bo
Medford, NJ US
182nd
1/25/2022 11:08am
Sounds like any 250f or 350 will fit the bill. Find the best deal and let it rip. I had an RMZ 250 (which I loved), and two 350s since. IMO, the 350’s only flaw is the air fork, which isn’t so much a flaw anymore because they’re actually pretty damn good on the latest gen (xact). If only KTM partnered with KYB though…
Grouper
Paducah, KY US
1/25/2022 11:09am
hylo wrote:
I’m really not the right person to answer since I am very biased. I like KTMs. Alot. I ride a 250 sx two stroke and have...
For like $400 more than the suzuki, I can have the 350 with all of the upgrades I'll have to do anyways like brakes, brake lines, etc. Plus, a bike that (according to media) likes to live up high in the rpms. I just need to find someone with a connection that can get me one shipped and I would be alot more motivated of a buyer. Thanks for the response.
If anyone has any connections, pm me or reply here. I would like know I have the option of even getting a gasgas.
Grouper
Paducah, KY US
1/25/2022 11:13am
austin_bo wrote:
Sounds like any 250f or 350 will fit the bill. Find the best deal and let it rip. I had an RMZ 250 (which I loved)...
Xactly! haha.... but foreal. Exactly. I hear the newest generation of air forks is up there with KYB in terms of rider feel. I really like that I can stiffen up the forks at will too. It's kind of a pain to do new springs too.
I also did consider just grabbing an RM-Z250 and throwing a pipe on it with a good map and keeping it pinned. At around 7600 dollars, there's room for that.
1/25/2022 11:14am
Grouper wrote:
No banter. I have always ridden RM-Z250's until a collegiate hiatus and now that I am on a YZ250 2 stroke I just don't feel the...
Your remarks about the KX are completely incorrect. It handles great. Very settled on straight line speed and once you get the suspension set to your weight and skill level it corners really well. The bike does need to be re-sprung for weight and ability, but that will balance the bike out as well. IMO the KX does everything good. Nothing great and nothing bad.
hylo
NO
1/25/2022 11:18am
Grouper wrote:
For like $400 more than the suzuki, I can have the 350 with all of the upgrades I'll have to do anyways like brakes, brake lines...
Yup! And those Brembos brake nicely also. It likes revving, but I used to live in the midrange on mine, but I could rev it longer than 450s and gain a few meters on starts that way…
Good luck and happy riding!
philG
1/25/2022 11:19am
I guess it boils down to the whether you want to go fast , or feel fast.
I am a 50+ vet now with an FC450 , and a also use of a YZF250.. i honestly feel that the 250 is too much like hard work as an only bike.
Grouper
Paducah, KY US
1/25/2022 11:23am
Your remarks about the KX are completely incorrect. It handles great. Very settled on straight line speed and once you get the suspension set to your...
It's high on my interest list. I am too far out of the acceptable weight zone for all current bikes so I'm going into the suspension regardless (except maybe the gasgas). That being said, do you think I would find the KX to be the bike of choice based on what has been discussed so far? 250 or 450? I lean 450 with the soft couplers.
I'm not worried about power. I think the YZ250 is really fast. I am more concerned with how the power translates to usability.
1/25/2022 11:25am
Grouper wrote:
It's high on my interest list. I am too far out of the acceptable weight zone for all current bikes so I'm going into the suspension...
The kx has really manageable power. I've owned a KTM 350 and KX450. I personally found the 450 to be more fun to ride. It never feels too much for me.
Grouper
Paducah, KY US
1/25/2022 11:26am
philG wrote:
I guess it boils down to the whether you want to go fast , or feel fast. I am a 50+ vet now with an FC450...
Strictly interested in removing seconds from the lap times. I'd ride a unicorn powered by liquified urinal cakes if it was what I was most comfortable on.
Grouper
Paducah, KY US
1/25/2022 2:46pm
The kx has really manageable power. I've owned a KTM 350 and KX450. I personally found the 450 to be more fun to ride. It never...
Thoughts on the suspension? I am likely going to revalve it immediately anyways, but I am kind of curious to know if other riders have gotten it set up well. It'll get new springs day one.
Falcon
Menifee, CA US
407th
1/25/2022 4:07pm
I'm a 2-stroke superfan (YZ250, in fact,) but it sounds like you don't gel with 2-strokes for the same reasons I don't gel with 4-strokes, but in reverse. (You like engine braking and having torque on tap at all RPMs.)
Since you mentioned you like to ride the bike hard, I'd aim you toward a 250F. You said you had to seat bounce a lot of stuff; my guess is that your issue was being down on power with the Suzuki. A newer bike from a brand with more power might be the ticket. Look at Yamaha, Honda or GasGas/Husqvarna/KTM.
Moto520
Schaumburg, IL US
1/25/2022 4:17pm
Ktm 350 s for
Ktm 250sxf
Yamaha yz250f
The 450’s are great if you had been riding them from day 1……20 years ago. If not…..the power is tough to deal with (this is the feedback I’ve gotten from people with your similar concerns). Personally…..I need one of each to match the track I want to ride.
Pirate421
MA US
1/25/2022 4:25pm
I was the same with my yz250s. I wanted to love them so bad but just could never get along with them. Too rigid, didn’t corner well and the power wasn’t very smooth. I got an FC350 and it was the best bike I’ve ever had. Yes you can ride it high in the rpm range, but, you really don’t have to. They have more torque than a 250f and they just don’t run out of power, ever. I lived on the east coast but for my vet b/c speed I never met a track that would force me to shift.
That said I have a XC tpi bike now and love it also. Wanted to try and build one bad but would love to have another 350 and will have another one someday when I have the money.
Phillip_Lamb
ORANGEVALE, CA US
2235th
1/25/2022 4:38pm
if you go the 4 stroke route: a newer ktm or yz250f has good power for bigger guys and really any 250 paired with cams, hc piston and an ignition will be an awesome time on the track
if you go a 450 the penalty is heavier inertia but lots of power.
a 350 is more like a hopped up 450. i've recently ridden an 11 rmz450, 17 fc350 and 16 ktm250sxf. the 350 was the bees nees and im looking for one in any color (orange white or red) at this point
if you stick it out with the yz250 here are some thoughts
I had an 03 and 17 both had similiar issues but it didnt want to lean on corner entry, so i changed to a taller bar that gave me more leverage but yours seems to have an issue coming out of the corner.
if you keep the 22mm, try drop the fork in the clamp, also try slowing down the rebound on the shock.
add a vforce reed block (or boyesen) and fmf or pc pipe combo with a standard length silencer. these will beef the middle a bit and give a bit more top end
you can have the head recut for pump fuel or run 50/50 leaded fuel. both of these will eliminate this issue
welcome to two strokes, you steer from the rear
the two stroke engine revs quicker than a 4 stroke and doesnt put its torque down as well, hence why the racing world went away from them. you have to work on your throttle control
mxracer666
NE Iowa, IA US
1/25/2022 4:45pm
Pirate421 wrote:
I was the same with my yz250s. I wanted to love them so bad but just could never get along with them. Too rigid, didn’t corner...
Agreed...everything he says he doesn't like is typical 2-stroke charactaristics. Just the way a 2-stroke feels...The KTM-family bikes corner very well (he is used to Suzuki's), but also aren't twitchy, and stable at speed. A 350 sounds like the perfect bike for this guy...
TXDirt
Plano, TX US
1/25/2022 4:47pm
This is a great starter bike
917rider
Hephzibah, GA US
1/25/2022 5:03pm
My new kx450sr is the best handling bike I’ve ever owned and I’ve had a lot !
Grouper
Paducah, KY US
1/25/2022 5:27pm
Moto520 wrote:
Ktm 350 s for Ktm 250sxf Yamaha yz250f The 450’s are great if you had been riding them from day 1……20 years ago. If not…..the power...
Ktm 350 s for
Ktm 250sxf
Yamaha yz250f
I feel that way. I was down in Florida at 74mx and idk if I could have been faster on a 4 stroke. But it was a fresh groom with like 4 riders that day so it’s not fair. I do know that I reached my wits end with the bike at monster mountain 2 days later. I really resonate with what you said about riding hard. I really feel by best when I’m on the throttle a lot and pushing it and only Eli Tomac at south wick in 2018 can ride a 450 like that😂😂😂
I may try a yz250f who knows.
I’m mostly afraid of losing 8 horsepower and wanting it back forever..
Grouper
Paducah, KY US
1/25/2022 5:28pm
mxracer666 wrote:
Agreed...everything he says he doesn't like is typical 2-stroke charactaristics. Just the way a 2-stroke feels...The KTM-family bikes corner very well (he is used to Suzuki's)...
Funny you say that.. I had a 2013 250sx and I think if I had gotten another ktm this go round I wouldn’t be in this boat. That bike was a little closer to what I liked minus the engine braking and power characteristics.
Grouper
Paducah, KY US
1/25/2022 5:34pm
if you go the 4 stroke route: a newer ktm or yz250f has good power for bigger guys and really any 250 paired with cams, hc...
“Steer from the rear”
I think this is honestly where me and the two stroke part ways when it comes to getting faster. That just may be the way the cookie crumbles. Blessed are we to ride in a time with options to let us feel this way!
“Throttle control”
Totally agree. I’ve actually been working really hard at using the clutch in conjunction with a focused right wrist to emulate a 4 stroke roll on. I’ve gotten really good at it I think, but I don’t think it’s quite possible to bridge the gap all the way. What do you think?
Thank you so much for the thoughtful response too. I appreciate it.
Grouper
Paducah, KY US
1/25/2022 5:36pm Edited Date/Time 1/25/2022 5:38pm
Do you think a bike is just as reliable as stock with those mods? I would probably spring for a 250 and maybe drop a piston and a pipe with a map in it. I feel like for the same price I could just be on a 350 as well though.
1/25/2022 7:35pm Edited Date/Time 1/25/2022 7:37pm
Grouper wrote:
Thoughts on the suspension? I am likely going to revalve it immediately anyways, but I am kind of curious to know if other riders have gotten...
I didn’t like the wp air suspension. Never rode hard on any kyb. With that said, I had my stock kx stuff done by factory connection and it’s the best stuff I’ve ever ridden. Super balanced and perfect for me.
Pirate421
MA US
1/25/2022 7:48pm
Dang man I just saw you are in Paducah I’m out that way. Have you checked out valentine valley Mx yet? It’s awesome
Grouper
Paducah, KY US
1/25/2022 10:02pm
Not yet, I have been out of town three times since it has opened and weather has ruined the rest. It looks awesome. I am really hoping the track prep is done well. With our dirt, that's the biggest thing.
Are you here full time? visiting?
Post a reply to: Wisdom Needed: Please help determine which bike is right for me
