Just curious if this is possible, I have a chance to get cheap spring forks from 2007 suzuki rmz 450, and I would try them on 2017 model if they fit right on?
Interesting.
With a flat-blade screwdriver & an air-pump, I was able to get the TACs to work pretty damn well.
I'd go take a look at the Kawasaki Video of "how to set up" the KXF fork (same fork/same base-line) before I spend any time or money.
I'm pretty happy with my TACs also, was just curious if it's an option. Seen 07 spring forks for sale for 150$ and had to ask. Thanks anyway.
Throw the race tech gold valves in, cheap as on ebay. Valving is way off stock. I also have the skf internals which is nice but not needed. Run zero psi in the outer, use extra oil if its bottoming. Run 10-20 more psi in the balance to make it plusher.
coastlinecascot wrote:Will 07 forks fit the 13 triple clamps
Nope. 2013 is 38mm sff spring, and the tubes were bigger
Yeah, if your valving is wrong, air spring or steel spring doesn't matter.
Problem with rmzsff air valving is way off
So the air spring gets confusing.
I wonder if it would be worth fitting a wp aer air spring to a showa?
i did this conversion after the bottom bolt on the original forks came lose ..destroying the internals .
Because the internals costs 850€ i bought a set of showa 2007 rmz 450 forks .
the difference is just a millimeter on the bottom triple clamps , cutting open a spray can and cut it to fit around the tube make it work perfect ..spring forks work better also !
If they're anything like the Honda Showa SFF Air forks, I really struggled to get comfortable and was seriously thinking about picking up some Spring forks. They were awful..
I sent them to Technix JP, and they put in the Innteck, SKF glide kit and SKF seals.
Completely changed the bike, love them now.
"Nothing happens until something moves"
