What oil to use
ristaone
Edited Date/Time 4/16/2019 11:23am
So im a green horn when it comes to dirt bikes so this might be a stupid question but can you use penrite mc4st 10w-30 semi synthetic oil in a 2007 special edishion yz250f dirt bike or 10w-40 full synthetic oil
kb228
Mansfield, OH US
4/16/2019 4:42am
Paging barnett to flame everyone on oil
Goon126
4/16/2019 4:55am Edited Date/Time 4/16/2019 4:58am
“Special edition”....this has trolling written all over it
ristaone
4/16/2019 5:09am
Goon whats trolling ment to mean im verry new to biking and have no idea
ristaone
4/16/2019 5:11am
yamalube 10w40
Is penrite 10w-30 ok or not and if i use 10w40 is full synthetic ok also where do i get yamalube 10w40 from
4/16/2019 5:17am
To answer your question...I don't know. I've never heard of this Penrite, and frankly, it sounds made up.
Yamalube can be bought in virtually every Yamaha dealership, and at roughly two jillion on line retailers.
mattyhamz2
So Cal, CA US
767th
4/16/2019 5:29am
He’s probably referring to the white and red(?) version Yamaha had.
mxb2
Bowie, MD US
4/16/2019 5:34am
To answer your question...I don't know. I've never heard of this Penrite, and frankly, it sounds made up. Yamalube can be bought in virtually every Yamaha...
Metcalfe is sponsored by them.
ristaone
4/16/2019 5:36am
Yes i am its red and white
danman
Readstown, WI US
4/16/2019 6:02am
It depends on the color of the power band you use. Some power bands just don't work well with synthetic oil.
BR8ES
Bennett, CO US
4/16/2019 6:19am
Just don't use Motorex as it is spec'd for KTM.
Moto520
Schaumburg, IL US
4/16/2019 6:19am
Hot topic! Yes. You can do it.
Goon126
4/16/2019 6:25am
I know what special edition means. I was just suspicious that he would mention that he has different colored plastics on a question about oil
mattyhamz2
So Cal, CA US
767th
4/16/2019 6:38am
I was thinking with him being so new he probably didn’t know plastic color was the only difference between the special edish and the regular. That’s the only thing I can think of
colvin227
Alamogordo, NM US
4/16/2019 6:52am Edited Date/Time 4/16/2019 6:53am
ristaone wrote:
So im a green horn when it comes to dirt bikes so this might be a stupid question but can you use penrite mc4st 10w-30 semi...
Hey buddy, yeah either of those oils would work. Most modern bikes call for 10w-40 and fully synthetic is totally fine. The key to these bikes are frequent oil changes because they hold a relatively small amount of oil and it gets punished in these high reving four strokes. Welcome to the moto community not everyone are the “cool guy douches” you may have ran into
spimx
Port Isabel, TX US
4/16/2019 7:59am
Whatever is jaso ma2, I buy it at the local auto parts shop since I change oil every other week and if you ship it they only ship by ground. Just look for motorcycle oil at your local auto parts even Walmart has full synthetic jaso ma2
4/16/2019 10:02am
Full synthetic oil makes clutches slip. Just get a motorcycle specific 10w40 and don't worry about it.
Hammer 663s
Forest Grove, OR US
4/16/2019 10:11am Edited Date/Time 4/16/2019 10:12am
Rotella. Can't believe no one's suggested it already! Everyone knows all the factory rigs dump out the OEM oil under cover of darkness and replace it with Rotella. Fact.
4/16/2019 10:33am Edited Date/Time 4/16/2019 10:42am
Rotella. Can't believe no one's suggested it already! Everyone knows all the factory rigs dump out the OEM oil under cover of darkness and replace it...
OP appears to be in Australia, so Rotella will be known as Shell rimula down there. OP I personally use 15w40 full synthetic in my 2016 450 SX-F, it's been a great oil and it's very cheap. For you, the equivalent appears to be Rimula R4, maybe give that a try. (I can't tell if it's synthetic so maybe not tan exact equivalent)
A lot of you muppets might want to learn how to help new users, rather than try and clown on them.
lostboy819
Somewhere, CO US
1442nd
4/16/2019 10:40am
You can put anything you want in it.
4/16/2019 11:10am
Specifically the red power bands can be used with full synthetic, but make sure to NOT use the yellow power bands with synthetic, as it will cause the left threaded discombobulator relay to come unwound and potentially seize the flux capacitor on the ATAC valve.
kb228
Mansfield, OH US
4/16/2019 11:23am
4/16/2019 1:26pm
kb228 wrote:
[img]https://p.vitalmx.com/photos/forums/2019/04/16/339263/s1200_3CC64100_DCBE_4EDA_AF6A_DB2B4638B8B8.jpg[/img]
Very informative response. Thanks for your contribution.
BobPA
PA US
4/16/2019 2:40pm
Fact you say? Prove it, that is a load of metric BS.
Also Squirelly, that is a giant myth....Motul, Motorex, Bel Ray, Castrol, Klotz, etc. must all make your clutch slip. PS : They all make full synthetic oils that are good for wet clutches.
Post a reply to: What oil to use
