- Pick trends
- Create a private league
- And more!
Thumpers are totally different because they run hotter and the same oil lubes the gears and the top end on some models.
Rotella ThumperTalk Fan Boys please save your breath with me. I'll give you one "Whatever" and that's it.
For example Honda oil has been made and packaged by damn near everyone if you look into it.
If it’s all about money, then I prefer to use oil designed for engines that cost over $30,000 and are expected to last a million miles.
I’m going to start a private oil label. I’ll buy Rotella T4 and transfer it into bottles with a motorcycle on the front. Not only will it be an awesome oil, but I’ll be able to mark it up 300%.
Most guys buying expensive oil are falling victim to good marketing and don’t even know it.
Run your cheap oil and enjoy risking your investment to save 5 bucks.
I sure don’t want my engine or the OP’s engine to “unexpectedly granade” as you so eloquently put it in one of your previous posts.
I personally wouldn't use the new formula though and Rekluse no longer recommends to uses it.
And of course KTM is going to recommend that you use Motorex synthetic, it's the most expensive oil and all of the KTM dealers sell it.
The new formulations to CK-rating have caused a ton of consternation in the diesel world but we don;t really have a choice but to run them as pretty much all oil manufacturers have gone to them.........
Same as most oil and race fuel companies.
The big changes for 2017 were primarily implemented to satisfy the new diesel engine spec: CK-4. The focus in this new formulation was on high temp shear, deposit control, and oxidation stability. The relatively high level of zinc that existed in the old formulation is actually slightly higher now, and soluble moly has been added as well. The tech support person said that the only minor concern is that high levels of zinc can contribute to catalytic converter damage/clogging but that otherwise, zinc is a big part of what makes T6 a superior oil for our motors.
"540 Rat-MOTOR OIL ENGINEERING". This is by far the most informative unbiased test I have ever read on over 200 engine oil brands, weights, chemical compositor and actual protection they provide. The engineer also has a specific section on motorcycle oils, clutches and explains the ratings. Its a lot info and reading but definitely worth looking into. It will explain a lot of the myths about engine oils and the protection they provide.
Hope this can help a few people out
Before that, their "Degummed Racing Castor" Im pretty sure was the old Castrol R.
Amsoil uses, or used Mobil1 base stocks. Who knows. Companies change supplies and packaging companies all the time.
The guy with the Rat 540 Link above, that paper is a helluva good read too.
Post a reply to: Shell rotella t4 diesel engine oil for yz250 2t?
