Soddy Daisy, TN
12/8/2015 5:32pm
Raised in So Cal I never learned how to ride ruts. I now live in TN and all the tracks have ruts. Been back riding about 8 yrs now and still don't have it down decent. I attended a Marty Smith school this fall and he showed me the trick of dragging the rear brake. It really works.
But, I have an awful time trying to get my foot in the proper position to gently touch the rear brake. My toe is always pointed down when I'm up on the tank executing a turn. What's the trick? Do you lower the brake lever? Or take your foot completely of the peg and just use your toe? I was taught, back long time ago, to push down on that outside peg. Thats what I do. Just can't do both.
I had an awful habit of dragging the rear, and once I broke it I found that I smoothed out my corner transition (brake to accelerate) considerably. The front sets the bike down a bit and to me it feels more stable coming into the rut.
Of course, I could be wrong. I'm not a pro haha
their rear brake in ruts until the apex. Same with the front brake.
Gary S. teaches this method as well.
Doug. D. would disagree with this.
Like someone else said, everyone has their own style/methods.
just keep your head up and ride through them like puddles
Learn something from you folk everyday
Dragging rear brake in a real rut while trying to turn is basically the Anti-Christ of what you want to do
i havn't noticed to much dragging the rear through the rut til the apex but like you said everyone has different styles
Dragging the front made the biggest improvement for me by far.
But still, I do slow-mo the pro races and pay special attention to their feet and front brake finger.
I think dragging the rear brake is more of a personal riding style thing. However, if you have both brakes on hard at the same time, it will take away from the suspension. Stand beside your bike (on the ground) and push hard on your rear brake and pull in your front brake at the same time. Then while your doing this, try to push down on the seat. You will find that the suspension will not move.
Probably good to remember if we are talking two strokes vs. four. I could see the point-n-shoot method working better for thumpers.
Regarding the OP, I'm wondering where you sit when you tap the rear brake while having your foot still on the peg
the other technique dubach is talking about is something tortelli was good at and tended to be more euro style. finish braking and leave enough momentum to coast into turn then get on the gas. the idea is to not use so much brake and focus on leaning over the bike more.
both styles work and are more a result of the tracks in each region. to me more american tracks had a bit tighter turn and loamier dirt which played to a 'point and shoot' style and allowed for powering through corners and from what i have seen, euro tracks have a bit more sweeping turns and the dirt is harder packed and the only way to hold momentum is to coast through it as applying power would put you on the ground
go to 3:19, some good tips on front brakes
Post a reply to: Ruts and dragging rear brake
