Arlington, TX
7/23/2013 8:56pm
About 6 years ago I had a 2003 yz250f (stock) and whenever I would run race gas in it, it ran WAY better. It almost felt like it burned cooler/slower so the power was way smoother. It felt like you couldn't beat the bike hard enough, like it wouldn't over rev or vibrate like it would on pump gas. It was like the bike had less power but way smoother power. Has anyone else experienced this? Everyone I talk to calls me crazy but I noticed a huge difference.
I forgot what type of race fuel I was running and I was wondering what type of race fuel would give me this type of performance again? I know everyone is going to say that it's a waste of money without a highly modded/high compression engine. However, I have felt the difference and it is substantial. I did have to adjust the idle up on the bike when running the race gas because it wouldn't start otherwise.
Does anyone know what I'm talking about? Any help would be greatly appreciated. Thank you!
I have tried race gas off and on and I can definitely tell a difference (on the track AND in my wallet). If I could afford it, I'd run race gas all the time but I can't even afford to buy pump gas ever since the po-po cracked down on my bitches working motel drive. It's hard for a pimp out here.
If you are unsure what kind to run, talk to someone (knowledgeable) at the local shop or call VP directly. Either way, you should get a good direction to go (based on the bike you're racing now).
TM
A stock 250f on MR12 and mapped correctly runs way better than it ever will with any 110 or 110/pump mix.
Try pouring T4 in your bike. You'll feel a substantial power gain and throttle response in a stock bike w/o the need for significant jetting or mapping changes. Also, you don't have to worry about cutting it with pump gas as it already carries a reasonable price tag for the performance offered.
VP Racing Fuels MX / Off-Road Page
Got additional questions? Call our tech - +1.812.878.2025
-VP Racing Fuels
If your bike is going to sit for any length of time pump it back into the metal can with this:
http://www.amazon.com/Sierra-Tools-Battery-Operated-Liquid-Transfer/dp/…
One of these pumps really makes emptying the tank easy.
Post a reply to: Race Gas Question, Please Help
