- Pick trends
- Create a private league
- And more!
135 hrs same plugs as the day it came home.
some people were using a light premix in the crfs or using marvel mystery oil to help w/ valve life
The fuel doesn't really know if it's in a 2 stroke or 4 stroke engine, the engine doesn't really know if you are putting fuel "designed" for a 4 stroke or 2 stroke in it, (unless you forget to mix in your 2 stroke oil.) Likewise with "motorsports" v "powersports fuels"...and VP doesn't really have 86 (or whatever) different unique fuels, although they may have that many mixes of petroleum dye...
the 100 unleaded and 110 leaded fuels that come out of a pump, like what Downs Oil sells here in SoCal for about 8 bucks a gallon are plenty good for 99% of the people
Tetraethyl Lead is your best octane booster so feel free to mix your 110 leaded in with your premium pump gas to save a little money.
MXR02 is badass, please use it at Mammoth in either a 2 or 4 stroke
A lot of the guys on the fuel trucks at the races, and at trade shows really don't know much, their best advise is to read the brochures..
A great deal of the basic race fuels and race fuel components come from a specialty chemical plant in Borger Texas that was built during WW2 to make 115/145 AvGas for the P51 The plant can produce much smaller batches (50,000 gal) with much better quality control than a normal refinery.
VP is not historically a refiner, they are a blender of fuels (My knowledge on this one is dated, so since they were "bought" by a major petroleum company, they could be...)
and YES to try to end the debate, much basic racegas is AvGas base )(because it's a very good starting point.) with 20 to 25% aromatic hydrocarbons, and a little dye added, or in the case of the old Cam2 gas, way too much red dye....
So you all can keep believing the Marketing teams or not....but remember, A&W's 1/3 lb hamburger failed because the majority of people think that 1/3 is smaller than 1/4
here are some i found from teh old days
https://thumpertalk.com/forums/topic/43745-marvel-mystery-oil-or-2-stro…
https://thumpertalk.com/forums/topic/938761-2010-100-hrs-no-valve-adjus…
Yes... and it's a fact that the gas:oil ratio directly affects the gas:air ratio (over rich mixture).
So, you're disproving your point while you think you are proving your point (that oil ratio doesn't matter)
Also, the lawn mower example - most mowers are air cooled and run at a set, high rpm. Which means they generally run consistently hot. Unlike a 2-stroke dirt bike where a fast rider in thick dirt with big hills will certainly generate a lot more heat and higher engine/exhaust temps than a slow beginner putt-putting around barely above idle on flat, hard-packed ground. So, it's not a very good example applicable to MX bikes. Also, 4-stroke lawnmowers are generally jetted on the lean side. When you add oil to the gas you have effectively leaned out the gas:air ratio even farther which makes them run even hotter.
When I asked how this passed emissions, someone here said that the emissions issue with two strokes comes from unavoidable port timing issues, not oil premixed with gas,
O
L
Stock RX7's draw their housing (apex seal) lubricant from the sump. Some car oils burned very dirty and caused carbon build up, which is a no-no in a rotary. Pre mixing really keeps the carbon at bay....along with plenty of WOT.
They also have a pump option at the Corona location.
Post a reply to: Proof that oil ratio and flashpoint have nothing to do with it.
