- Pick trends
- Create a private league
- And more!
Maybe try bleeding the brakes first and see if that helps.
https://youtu.be/NL-o0uL6bng
I run Galfer lines, sinter pads with the Tsunami Superlight Oversize Wave Rotor. Besides the caliper and master, it's pretty close to factory.
You could buy the Brembo SXS calipers:
Does the oversized rotor help that much on the ktm? I've heard it's a must on the jap bikes but never thought about on the ktm..also did the brake lines improve a lot or did u do it all at once?
I like the oversize floating rotor because it gives you more grab but he floating makes it feel more progressive and not grabby/lock up.
Post a reply to: Pro factory parts?
