Phoenix, MD
12/27/2019 6:41pm
So I did something stupid. I siphoned the gas out of my bike for the season. I drained it until I could barely hear anything in the tank when I Rocked the bike back and forth on the stand. I started it and let it run to get the rest of the fuel out (40 degrees Fahrenheit here). I checked on it every two or three minutes until I had to do something in the kitchen. When I came out after about ten minutes it was steaming and radiator fluid was dripping on the ground.
The bike has about 15 light hours on it (2018 yz250f). Do I need to take it to a mechanic? Or should I refill the coolant and just learn from this experience?
PawPaw
I have said this to many people, have to think of your bike like a shark, if it's not moving, it'll die. (Some sharks need to swim in their sleep)
Just keep swimming, just keep swimming
Take the tank off and drain it next time like a sane person.
IMO if your not getting coolant in your oil and you have compression and the leakdown test is ok then dont worry about it. Id definitely do all 3 checks before riding again. Never know what freak thing happened.
If you decided not to do this keep a very close eye on the oil for the first couple rides to make sure no coolant is getting into it and also on the coolant level in the radiators to make sure non is being consumed.
"I over-heated my YZ250F"
"I used 10/40 for pre-mix!!"
"I let my bike idle with 150ml too little oil in it!!"
Guys, c'mon, really? None of these 'mistakes' are likely to be 'fatal', but IF they were, IF they were, WTF are you going to do about it now?? Whats done is done, you can't change it. Go back to base, do as per manual and try it out to see if you've damaged it. "Will it be ok?" posts on Vital aren't going to help you now son.
I would at least change the oil/filter and look for metal. Maybe even pop the head off and check out the cylinder...
Maybe you just heat treated all the metals and now she'll last 10x longer!
Was burping coolant right as we found our way. I opened it up down the dirt road to cool it off and refilled the coolant later, no issues afterward
Post a reply to: Overheated bike running out the fuel.
