Huntington Beach, CA
1/27/2012 12:36am
Been looking at this for my 01 RM250 due to the grabby clutch....... but on the fence regarding using it.
Would like to hear you guys input (pros vs cons) on using this stuff for a 2 stroke bottom end.......
The bottom end is lubed by the oil in your fuel. Surprisingly many people don't know this.
I always kept a TypeF ATF in my tool box incase the clutch started slipping at the track to save my second moto!
Regarding the viscosity of gear oil vs engine oil, as a reference,
10W-40wt engine oil is roughly equivalent to 75W-90wt gear oil and
15W-50wt engine oil is roughly equivalent to 80W-90wt gear oil.
Gear oil and crankcase oil SAE viscosity grades are not equivalent.
The following chart shows the relationship of "real" viscosity to
their S.A.E. assigned numbers. The relationship of gear oils to
engine oils is also shown.
_______________________________________________________________
| SAE Gear Viscosity Number |
| ________________________________________________________ |
| |75W |80W |85W| 90 | 140 | |
| |____|_____|___|______________|________________________| |
| SAE Crank Case Viscosity Number |
| |10| 20 | 30 | 40 | 50 | |
| |__|_____|____|_____|______| |
|_____________________________________________________________|
2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 34 36 38 40 42
viscosity cSt @ 100 degrees C
Basically, you can use standard motor oil, as long as it does not
have the "energy saving" logo on it.
Thanks again!
Also Lucas Oil Semi Synthetic 10w-40 and you can go twice as long between oil changes on the big bikes.
A tip is to add 10% of the Heavy Duty Oil Stabilizer to the total refill capacity (90% oil / 10% HDOS) when doing your oil changes. If not comfortable using the 10w-40 there is a 20w-50 available or even the 15w-40 TBN Diesel oil too. The HDOS will not make your Clutch slip! The “Synthetic Heavy Duty Oil Stabilizer” may cause some slipping if too much is used. (I experienced that during our 50cc days mixing / adding with full synthetic 5wt oils).
My oldest Step son uses it in his bikes (250F & 450F) for the past few years, races in the +25 and Pro classes and experiences no problems whatsoever with the 10w-40 or the 20w-50 mixed as mentioned above.
Our 2008 KX 85 has only gone through 1-set of clutches during four seasons of races and non-race practice sessions, using the above 10w-40 set-up described above. (Trace pulled 4 Holeshots Saturday on a 2 1/2 year old clutch).
Changed the oil in our 125 after Zach's 4th moto Saturday & 6 1/2 hours of time on it since I rebuilt the motor after purchasing the used bike and it could have gone longer. It was brownish in color but not black or burnt etc. Put some on a paper towel and it was a dark golden color with no signs of clutch fiber goo.
Hope this helps in your choice of what to use.
JG.
Thanks!
Post a reply to: Opinions on Using ATF For Bottom End in A 2 Stroke
