One machine to build a mini bike track
2/17/2021 12:05 PM
If you had to rent one machine to build a mini track over a 1 acre area. What would you rent
2/17/2021 12:05 PM
Skid steer
I'll keep my guns, freedom and money, and you can keep the "change"
2/17/2021 12:40 PM
Agree with Skid steer (with tracks), get one that is at least 8 or 9K pounds, you might even be able to tow it yourself to save dollars on a delivery charge. With a decent size machine and 1 acre you could build a pretty nice little track in one day if you are decent at running the thing. Make sure the loader bucket on the front has teeth (not smooth) for digging.
2/17/2021 12:46 PM
What's the dirt? Loose, packed, clay, sand? Skid steer ok if dirt is right, and it has a ripper. 30 HP tractor with a bucket, ripper, and tiller might work well too. You can build small jumps and good bowl turns with either. Each does a better job at certain types of finish work. Supercross style or turn track or ????
Hammer 663s.
2/17/2021 1:43 PM
Definitely skid steer or skip if that’s not an option
2/17/2021 2:01 PM
HondaFan33 wrote:
Skid steer
X2
PawPaw
2/17/2021 3:21 PM
Yup, big track dozer hands down. Mini track - tracked skiddy. Second would be a front end loader tractor mainly because implements are numerous & cheap.......That said doing the basic layout with a 450 sized dozer would expedite things immensely unless dirt is sand/soft then finish with skiddy.........
2/17/2021 4:12 PM
skid steer. and one with tracks instead of wheels.
2/17/2021 4:17 PM
Definitely a compact track loader.
21 WR450 | 21 CRF110 | 12 WR450 | 06 YZ250 | 04 TXT 280 Pro
2/17/2021 4:36 PM
Where is the dirt coming from? Native or being trucked in?
2/17/2021 6:19 PM
If you never ran a skid steer before plan on at least 1/2 day wasted on figuring things out. Amazing how quick someone that has experience can move dirt and make it look easy
2/17/2021 6:37 PM
Cat 289D Compact Track Loader or the equivalent.
