Muskegon, MI
3/23/2020 5:52pm
... I need help replacing the chain.
I was given the bike below for my Electrical Engineering Senior Design Project. All I know is that it is a Yamaha and it is old.
My brother is a tool maker and welder and with his help, we successfully mounted the electric motor, the Prius battery (Lithium Ion batteries were not in the budget), and the controller. I wired everything up and we were ready to ride (on asphalt as we have not built a water/dust tight enclosure yet). Problem is, the chain that came in a bag with this bike is 8 inches too short. I need some help knowing where to buy a chain for a bike this old. The chain that came with it is either the wrong chain or someone cut it down because the sprocket on the electric motor is almost in the same place the gas engine was.
Does anybody know what model and year this bike is?
Who sells chains for old bikes like this?
What dimensions need to be measured in order to buy a replacement chain?
That sprocket looks like the wrong width/pitch to me to match the rear sprocket, but you can deal with that however you choose.
https://www.rbracing-rsr.com/chainlength.html
https://www.rbracing-rsr.com/calcsprocketdiam.html
https://www.lamar.edu/engineering/enginuity/mechanical-baja.html
I
Here's what I found.
Often times your own research can help you know the right questions to ask.
Also, it helps you build research skills and experience so you can avoid being the guy who makes a career asking someone else to make every design decision for you.
Post a reply to: Old Yamaha Revived with Electric Motor but...
