Beverly Hills, CA
499th
I did an oil change shortly before putting my bike away for winter. Only have around 2 hrs ride time. Is there a time limit for the oil where you'd want to change it after a certain amount of time regardless of hours ridden?
So to sum things up: do the oil change and empty the gas tank (gas gets bad from just sitting around, better store it a metal canister) before winter and when you want to ride, put gas in and ride.
Not sure if 6 months is too much though.
By now, the oil in your air filter has probably dried up and/or migrated, so you should change your air filter.
Check out Dirtbike TV with Jay Clark if you get a chance. He speaks on maintenance issues on bikes and it's really good stuff.
In your situation, you'll be fine. Just treat it as you would any oil with 2 hours on it. Change it per your owner's manual when you reach the allotted time.
To sum it up: Do an oil change before the bike goes into the garage for the winter and it’ll be still fresh when it’s time to ride again.
Post a reply to: Oil duration question
