Erie, PA
alphado
7/11/2015 2:11pm
7/11/2015 2:11pm
8/9/2015 6:30pm
Having trouble with Joe's 2003 KX125. Runs great, after he does some laps and lets it sit it won't start back up. Pulled the plug, it is tan but soaked with gas. Put in a new plug and it starts right up. Happened every time he came in. Thoughts?
Joe = Joey. Alph's toddler that smoked Reed on his powerwheels. Can't believe he's on a 125 now.
Weak spark can be a grounding issue, clean the mounting for the coil & make sure there's no rust on the connections .
Then clean all the wires of corrosion, also pull the plug cap & clip 1/8 inch off the plug wire to get a good connection .
Pull the stator & clean the mounting connections , if you don't get a better spark it's time to break out the multimeter & the manual.
Hope this gets Joey up & running!
Howard
You should have at least 150 psi.
Post a reply to: Need help with Joe's bike
