Swansea, MA
6/19/2014 12:03pm
Hey guys I have a 2011 RMZ 250 and it seems to not want to run right at all. It will start then start bogging out and popping. It only stays running with gas. Once we shut it off it wont start up again easly. We did a cylinder leak down test and it checked out okay. We replaced the stator and that wasn't the issue. We have also tried to rebuild the top end as well as check my valve clearance. We also removed the wiring harness and inspected connections ect. At this point I am sorta puzzled as to what is wrong anyone have this issue?
Sounds like it could be the valve clearance
Post a reply to: Need help: 2011 rmz 250 bogs out
