Need help 2002 Honda cr 125
3/17/2018 7:09 PM
When trying to start it is getting water on the spark plug. Any ideas?
3/17/2018 7:12 PM
Edited Date/Time: 3/17/2018 7:12 PM
Head gasket / warped head
Washed up moto and enduro weekend warrior.
3/17/2018 10:08 PM
Did you recently have the cylinder off? Does it have the extra coolant drain bolt on the left side of the cylinder? If you don't remove that bolt and drain it coolant will drop into the bottom end when you pull the cylinder up. Then when you try to start it the coolant keeps getting tossed up on the plug.
In any case, regardless of how it got there you can get rid of most of the water by removing the plug, turning the bike upside down, and cranking the kicker over a bunch of times. If it's still getting water you have a head gasket problem.
Powerband in every gear !
