Cromwell, CT
190th
Was riding along in 5th gear, engine cuts out/stalls. Starter motor won’t turn over. Wait 20 minutes then it turns over starts, runs ok but won’t idle stalls repeatedly. Only has 10 hours, is the battery bad? The ground strap looks fine, all connections tight. Thanks for any help, on off road riding vacation, don’t trust it getting stranded.
Good luck.
Milky, metal flakes?
And if it’s getting lugged around at low speeds, you’re better off with a 1.8 cap.
Wish I could help, but that’s all I’ve got
https://m.youtube.com/watch?v=1j9K5mveQnU
If it’s not mechanical check the charging system to see if it’s pulling your battery down.
Post a reply to: Need advice- 2020 KX450 cuts out, won’t start, starts, difficulty idling
