NEED HELP WITH YZ250 NOW
11/8/2017 3:32 PM
My 2001 yz250 dosent idle...i have a keihin pwk 38 carburetor. i have to keep reving it to keep it alive.... i can full throttle 1ST GEAR and it dosent even pick up and do a wheelie. ..my floats are leveled and my needle position is at 1st (top of needle) postion and a 178 main jet ... do i need smaller or larger jets? Or needles idk ..help me out i want my bike to be a regular 2 stroke again
11/8/2017 3:33 PM
This won’t go well
11/8/2017 3:37 PM
Well.. Perhaps you need a Kickstarter that doesn't wear-out your boots. That may fix the issue.
11/8/2017 3:38 PM
IN.
if you're gonna be dumb, you better be tough
11/8/2017 3:51 PM
lol!
Purple power band should help it. That's the best one.
2017 RMZ450
2005 YZ250-sold :,(
1998 YZ250
2005 KX250F
Thanks to : Factory Effex, Simi Valley Cycles, N2Dirt, Acerbis, DT1, Fasthouse, Matix, FMF, Mika Metals
11/8/2017 3:54 PM
Sorry man, theres no way its going to be a regular 2 stroke again.
Youre going to have to accept it for who it is now.... But hey its 2017 and we need to be accepting of those who are different.
11/8/2017 3:56 PM
How does she wheelie in 2nd gear?
11/8/2017 4:14 PM
What do the reeds look like?
11/8/2017 4:26 PM
Remove carburetor. Remove float bowl. Remove main and pilot jets. Inspect jets for any accumulation of shit. After seeing that the pilot is plugged, remove said shit. Put back together in reverse order.
11/8/2017 4:30 PM
Edited Date/Time: 11/8/2017 4:30 PM
Make sure that the powerband is stil there , sometimes will get lose and fell out.
Born in Prague,living in LA,so if you don't like my spelling,blow me!
21 CRF450R
16 Yamaha YXZ 1000R
17 Yamaha MT-10 FZ-10 165 Hp RWP
20 CRF450L supermoto
96 CR250R smoker
2012 CR500AF
1987 KX500
11/8/2017 4:32 PM
Edited Date/Time: 11/8/2017 4:33 PM
Replace the jets and go from there. I won't assume you have any mechanical knowledge whatsoever.
And see 2 posts above mine.
11/8/2017 4:36 PM
Much ty
much ty. How to spot a paid forum poster/artificial forum traffic producer (see list of actions/phrases below):
Copius pattern amounts of phrases like “Anyone have”..., “Anybody know?”.... and their variations.
Thoughts?
Any help is appreciated!
Thanks in advance!
11/8/2017 4:36 PM
reded wrote:
Remove carburetor. Remove float bowl. Remove main and pilot jets. Inspect jets for any accumulation of shit. After seeing that ...more
But if he puts it together in reverse order, wont bike bike only go backwards?
11/8/2017 4:44 PM
Rebuild the top end. Decarbon and clean your power valves. Blow out the massive dent in the pipe. Repack the muffler. Fit a BR8EGV. Put needle back in the centre clip and fit a 48 pilot. Clean and re-oil your air filter. Brapppp!
11/8/2017 4:56 PM
2021 KTM 350 SXF
2006 KX250
11/8/2017 5:28 PM
What fuel are you using?
www.MotoHose.com post knee replacement Moto Hose is again open and shipping orders.
Thank you all for your patience during my recovery.
11/8/2017 5:59 PM
One had a bum leg last I saw.
11/8/2017 5:59 PM
non ethanol 93
11/8/2017 6:02 PM
jabudhibb wrote:
non ethanol 93
From the pump?
11/8/2017 6:30 PM
Change the oil filter bro. They tear easily and that causes loss of power in the first wheelie gear.
11/8/2017 6:32 PM
11/8/2017 6:34 PM
Is the 450 one the same? If so I have a couple that I never used from my 01 YZ450F. I can make him a killer deal on them.
11/8/2017 7:04 PM
Yes, the 450f oil filters are exactly the same as the 250 2 strokes.
11/8/2017 7:12 PM
jabudhibb wrote:
non ethanol 93
Pull the head and see how much damage there is from detonation. You must use Race gas in these YZs
11/8/2017 7:17 PM
Retard the timing.
And that's not an insult!
11/8/2017 7:20 PM
kzizok wrote:
Much ty
Uh oh. Haha!
11/8/2017 7:23 PM
That's what I thought but I wasn't sure, I didn't want to give any bad info so I wanted to double check.
11/8/2017 8:36 PM
Check the piston nuts. A metric crescent wrench is necessary to properly torque them.
11/8/2017 8:55 PM
Can’t forget the muffler bearings and spark plug springs
2017 RMZ450
2005 YZ250-sold :,(
1998 YZ250
2005 KX250F
11/8/2017 10:16 PM
Don't listen to these guys Billy no idle. You just need to adjust the idler gear and pulley
