DE
7/29/2019 12:58pm
Hello everybody,
here and there I've stumbled over products where I thought: "That's cool!".
Things that are cleverly constructed and might make your life easier.
For example this lay over stand:
There was also the story of the inventor here at vital:
https://www.vitalmx.com/forums/Moto-Related,20/My-Story-Lay-Over-Stand,…
Or this quick release triangel stand:
Or even this adjustable stand:
Ok, maybe I'm a bit heavy on bike stands but do YOU have some products in you mind where you thought: "That's cool, that's something different!" ?
an interesting idea. I heard it actually worked, just never caught on.
Also, rear stands for RR bikes.
I added a little too much oil and was trying to drain some of it. The sight glass is on the right side so I was holding the bike level from that side. The stand fell out, so I’m squatted down trying to keep the bike from tipping while screwing in the drain plug 😂 That was almost a clown show
2. Risk Racing Seal Doctor - I've never met a leaking seal I haven't been able to "fix" with the Seal Dr. Tool.
SealSavers trap dirt and mud and make the seals go quicker. You must get a lot of use out of that Seal Doctor
On a side note since you're looking to challenge a friendly post did you realize you get longer life out of sprockets and x-ring or o-ring chains if you don't lube the x/o-ring chain but rather just clean it when cleaning your bike? I've done controlled testing over 1,000's of documented hours and the data strongly supports my statement. My son and I run same exact bikes on same exact tracks riding same exact hours with one chain lubed and the other just clean and dry. The clean and dry x/o-ring chain/sprockets far outlast the lubed chain to the tune of right at 50% longer life expectancy.
Flame suit on but I'm being serious.
Post a reply to: Innovative products for MX
