Englishtown, NJ
Hey guys,
First oil change on my 2019 KTM 250sx-f. Super annoying as the drain plug hex is not actually 12mm but closer to 13mm.
Anyways after changing oil, I'm pretty sure I let the bike idle for 2 mins with about 800-850ml of oil in it. No revving etc. Any chance I was starving the pump pick up? Basically filled it up with 1100ml (incorrect I know, s/b 1000), and took a bit too much out. After the initial idle, I let the bike cool down for a minute and checked the oil sight. There was barely any oil showing in the sight even with it leaned a bit towards me. That is when the panicking ensued.
Any issues idling with lowish oil? Trying to sleep tonight.
Thanks
Thanks
In all reality chances are you’re totally fine. I would make sure it has the proper amount in it and forget about it. Remember, bikes usually end up on their side sooner or later and that doesn’t blow them up, so they’re pretty hardy as long as you’re in the ballpark.
Also, go ahead and toss that 12mm to the back of the drawer because 13 is the new 12. Austrian bikes aren’t built to JIS standards.
https://cr4.globalspec.com/PostImages/201004/AnsiDinJisMetric_39600D3B-…
With all that being said, with 800 in your bike, you’re fine!!
Euros and Japanese do things differently.
I am sure your bike is ok. The oil pumps are easily accessible on KTM's...take the cover off and look.
In any case, your oil pickup will probably continue to work even at very low oil levels, so you probably never even starved your engine for oil. If you did, idling is probably OK for a short while.
Post a reply to: Idled bike on lowish* oil
