How do I rid myself of that annoying 2 stroke pipe rattle that makes my '13 250SX sound like a '77 RM 125?
1/8/2019 1:21 PM
Edited Date/Time: 1/8/2019 1:21 PM
Hey gurus! I come to you for your knowledge and experience.
I have a '13 250SX that sounds rattly and old and it's all from the exhaust pipe. I have replaced the pipe O -rings, the entire exhaust port on the cylinder (they are replaceable on KTM cyclinders), verified everything is tight, nothing is touching, and so on.
When I install the expansion chamber with fresh O-rings the bike sounds like Dungey's factory 2 stroke from Straight Rhythm, for about 15 minutes, then goes back to sounding more like a clapped out '77 RM125.
What's the secret? Gasket sealant at the head pipe possibly?
Please advise.
2013 KTM 250SX on Ohlins, 314cc built stroker engine with 56 very smooth and easy to ride rwhp.
1/8/2019 1:42 PM
Hi temp silicone?
1/8/2019 1:47 PM
What he said. Silicon around the o-rings and where it goes into the silencer
2011 Yamaha YZ 250 -MX
1996 Yamaha Banshee 350 -Trails
1982 Chevy S10
2005 Pontiac GTO -451rwhp
1/8/2019 1:52 PM
Edited Date/Time: 1/8/2019 1:54 PM
Buy a four stroke...you're giving two strokes a bad reputation. But seriously, try using Viton o-rings that are slightly oversized. They'll hold up to the heat much better and longer than a standard butyl rubber o-ring.
1/8/2019 2:00 PM
And what the hell is wrong with the way a 77 RM125 sounds, may I ask??? cool
1/8/2019 2:01 PM
I loved the sound of a 77 rm 125!
1/8/2019 2:04 PM
DAMN RIGHT !!!! LOL My first real race bike
1/8/2019 2:16 PM
I have a '13 250SX that sounds rattly and old and it's all from ...more
Buy a counterbalanced new bike!
Im not for sure on this - but after x amount of hours I've noticed the steel frame bikes just ring and rattle a ton!
1/8/2019 2:35 PM
2007 CR125 was pretty common with this concern.
From memory, they ran thin rubber washer behind the stainless ones on the mounts. But i would check the carbon build up and then run a slightly thicker O-ring. as mentioned the gasket sealant wont do a lot. rubber hose over the expansion chamber springs was another trick used to help reduce that "ting" sound.
On my CR we would run a gasket that was cut out for the exhaust port onto the cylinder as well as the O-ring and then we changed the springs to a different style that was a lot thicker. the OEM springs where pretty thin and would stretch and vibrate heaps.
all the best!
1/8/2019 2:39 PM
From memory, they ran thin rubber washer behind the stainless ones on the ...more
Those are good suggestions.
Thanks!
1/8/2019 2:44 PM
Silicone the joint between the pipe and silencer as well. Sometimes that's a spot for rattling and the sound may propagate down the pipe toward the cylinder.
Braaapin' aint easy.
1/8/2019 2:45 PM
Not a damn thing, they sound awesome!
1/8/2019 3:48 PM
Edited Date/Time: 1/8/2019 3:48 PM
Usually they are actually hitting the rh side of the engine due to a slight bend. Crank up bike and pull out on expansion chamber and rev and see if it still does it. Also, Most use rtv on the muffler as well as o rings. Your flange may be worn too.
sponsored by zip tie, JB weld and peanut butter and jelly
1/8/2019 3:59 PM
Buy kreft moto o rings. The bills pipe is the only one I've ran that doesn't rattle with stock o rings. Even the kreft last only a few hours with a pro circuit because the shitty fit. I had a friend tig weld part of a destroyed bills onto a stock pipe because the part that goes into the cylinder fits so nice. I heard fmf fits well too
