Fenton, MI
9/19/2018 5:55am
I have a 16 CRF250. I had FC do the valving and respring the rear. Mostly feel really good, Im 195lbs, B rider. These forks are still not good for me. I was at a rough track yesterday, and the fork harshness was insane, mostly bad on braking bumps. I rode a buddys older CRF450 w suspsension done by Weisner in MI, and his fork felt literally a world better, but its a spring fork. He is a 185 lb A rider. Is a spring kit needed to get good feel? Anything else to try? I dont know if I should keep dumping money into this or just get a new bike.
Find a set of spring forks and be done with it. I've got an A kit i'm going to put for sale shortly thats spring, that I used to avoid running the SFF TAC forks any longer on my kx.
- If it is the initial movement just add pressure to balance chamber (bottom of the fork, more pressure = softer initial movement).
- If it is in the middle stroke, drop the pressure in main chamber
- If it is the end of the stroke use the outer chamber (less pressure for softer, more pressure for harder).
The compression and rebound clickers work just like in spring unit.
I already paid for the revalve, so adding the spring conversion may be my cheapest option. I will probably do the spring conversion, unless it still wont be as good as starting w a known good fork. Anyone know?
Im 38 and dont have the energy I used to, so the lack of plush feel is really tiring my arms out.
Post a reply to: Honda Air Forks- Need some help adjusting harsh feel.
