- Pick trends
- Create a private league
- And more!
Does accelerating out of corners in 2nd gear wear tyres faster than accelerating out of corners in third gear? (less wheelspin?)
This has been the magic combo on my previous KX450 as well as my current KX500:
DID X-Ring chain.
Ironman Dirt Tricks rear sprocket.
Renthal (or equivalent) front sprocket.
The Renthal front sprockets will wear first, the X-Ring chain second, and then finally the Dirt Tricks rear sprocket. Most times I'll wear our 2 or 3 countershaft sprockets, and 2 chains before I'll put any noticeable wear on the rear sprocket!
And for what it's worth, I'm running 14-49.
Good luck dood!
What bike are you running 13-53 ?
https://motocrossactionmag.com/forgotten-motocross-tech-eyvind-boyesens…
Seat Bounce or throttle blip lift off of jumps is easier with a smaller sprocket. Bigger c/s sprockets have much less of that effect.
Post a reply to: Help settle a sprocket debate
