ORANGEVALE, CA
2362nd
I have an 04. I running stock 12/50, i feel like there is a big gap in between 2nd and 3rd.
Do i go up a tooth to.use 3rd or drop to use 2nd longer amd 1st.for.tight corners?
What are the rest of my rm army boys using?
I'd add one tooth to the rear and try taller gears in the corners. By the way, your bike goes faster at lower RPMs in a taller gear than it does at high RPMs in a shorter gear. Try 3rd in the wider corners and you'll be a believer.
normaly i have always geared the other way on 125's.. but they didn't need a 30$ spark plug either.
hope that helps, my bike was an 07
Post a reply to: Help rm125 gearing
