NC
6/24/2019 10:23pm
Trying to help a buddy out with his '98 YZ250 rebuild/resto project... Not much luck on eBay... Would really prefer to locate these parts as NOS or as new as possible; but let me know what you've got - Thanks in advance for any help or leads!!
3XK-18540-01-00 SHIFT CAM ASY (92-98 YZ/WR 250)
4EW-16381-01-00 PUSH LEVER COMP (93-98 YZ/WR 250)
4JX-17411-00-00 AXLE,MAIN (94-98 YZ 250)
4MX-17151-00-00 GEAR,5TH PINION (95-98 YZ 250)
4XL-17231-00-00 GEAR,3RD WHEEL (97-98 YZ 250)
3XK-18540-01-00 SHIFT CAM ASY (92-98 YZ/WR 250) You need to search for only 3XK-18540-01 When the -00 is left on the end, nothing comes up. If you search for 3XK-18540-01 without the -00 the search shows a NOS item.
Here is the search for a new 3XK-18540-01-00 without results https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=3XK-18540-01-00&_sacat=0&LH_TitleDesc=0&_osacat=0&_odkw=3XK-18540-01&LH_ItemCondition=3&rt=nc
Here is a search for 3XK-18540-01 with results https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=3XK-18540-01&_sacat=0&LH_TitleDesc=0&_osacat=0&_odkw=3XK-18540-01-00&LH_ItemCondition=3&rt=nc&LH_TitleDesc=0
Here is the new shift cam from those results https://www.ebay.com/itm/GENUINE-YAMAHA-YZ250-WR250Z-91-98-GEAR-SHIFT-DRUM-CAM-ASSY-3XK-18540-01-NOS-NLA/303002168760
Here is another example of dropping -00-00 on the 4MX-17151-00-00 GEAR,5TH PINION (95-98 YZ 250) Here is a NOS part that appear in a search for 4MX-17151 https://www.ebay.com/itm/YAMAHA-YZ250-1995-1998-TRANSMISSION-GEAR-5TH-PINION-21-TOOTH-21T-4MX-17151-00/273845181773
Another thing about Yamaha part numbers is sometimes parts are compatible even if the part numbers are a little off for example sometimes XXX-YYYYY-00-00 is the same as a ZZZ-YYYYY-00-00. This front end number change is can occur when a bike model is updated drastically but that particular part stays the same. Another change that can occur with compatible parts is the end numbers may change for example XXX-YYYYY-00-00 will change to XXX-YYYYY-01-00 and the only difference between the parts will be the finish or paint color, or maybe they are Jets and one is a #150 and the other is a #160, or maybe its sprockets and one will be a 14T and the other a 15T. Be careful crossing up part numbers like this though because there are also examples where the parts are actually incompatible even though the numbers are very similar.
Maybe someone can weigh in on your bike and the compatibility of trans parts. Maybe something newer or older will work. That will broaden what parts you can search for. Good luck.
http://www.speedandsportinc.com/
Get more generic in your searches. Look for '1998 YZ250 transmission', or even just 'YZ250 transmission' and filter out everything you don't want.
The parts you need will be on ebay at some point if they aren't now.
I part out old bikes & engines. I'm sure I've had these parts at some point. However, I and many, sell the whole transmission as one assembly. It is simply too tedious to list the transmission piece by piece (at least for me).
Post a reply to: Help locating discontinued '98 YZ250 tranny parts - NOS preferred
