Hillside, NJ
5/29/2017 6:41pm
Hello guys
i got my new KTM sxf 250 2017
i need your help with set up the wp and forks im sorry for being stupid but i read this review
http://motocrossactionmag.com/mxa-race-test-2017-ktm-250sxf/
hope its ok to post other link
and they said in the forks best set up is
Spring rate: 140 psi (154 psi)
Compression: 20 clicks out (17 clicks out)
Rebound: 15 clicks out (17 clicks out)
Fork-leg height: Third line
agian im sorry for my know ledge
but what they mean when they say
Rebound: 15 clicks out (17 clicks out)?
like in the forks i have in compression and rebound 20 clicks
what it mean 15 clicks out ( 17 clicks out )
like choose one 15 or 17?
please if can someone explain me
much ty
much ty
That said just play with it until you like it. I personally wouldn't run 140 psi, I think it will push in the corners. Air pressure makes a big difference, play with it too.
yea 140 psi sound low to me
maybe what in the () its their set up recommend?
lets wait for more people
Spring rate: 9.7 bar
Compression: 15 clicks out
shock
hi speed comp: 1 1/2 turns out
lo speed comp: 15 clicks out
rebound: 9 clicks out
STATIC sag: 25mm
Ride sag: 98mm
Still testing....i like a 100 vs 110 rear tire, 50 tooth vs 51 tooth rear sprocket,,,, trying the longer throw grey throttle cam next week.
and how much kg you are?
160lbs
+30 novice/int ability
and how much is 9.7 bar
its 140 psi?
and how many clicks again?
you mean like 15 clicks from 20 or from the stock?
like close it until the end and then open 15 clicks?
and how about clicks in rebound and comp?
elikoz
Scooter gets it.
Post a reply to: Hello guys need help with Set up on SXF 250
