Boise, ID
3/29/2018 6:38am
Alright - since not EVEN the local dealer knows which trans oil I can and can't run in my 2018 KTM 150sx I'm turning to you all.
Don't lead me astray haha
Can I use this for my transmission oil changes on my KTM 150sx - Keep in mind I never go more than 2-3 hours without an oil change.
https://www.google.com/aclk?sa=l&ai=DChcSEwiz5NeSrI3aAhWJXn4KHQwrC3UYAB…
Thanks!
Thanks!
There are a lot of transmission oils out there to choose from. Anything 80W to an SAE 90 should work fine. Just make sure it is wet clutch compatible.
The KTM doesn't have separate engine oil and trans oil.
I've been using Rotella 15/40 for 60 hours and she's holding up nice! If you want a moto brand, check out Motorex, Motul or Maxima for 15/50
I use Rotella in my 250F, over 100 hours and no broken parts.
I owned a 2010 150sx and put 140 hours on it. Since I wasn't a big clutch abuser I changed the oil every 30 hours. I tried a motul tranny oil once but used standard motor cycle engine oil (think it was motul 10W-40) because I liked the clutch actuation better.
@ CarlinoJoeVideo: KTM two strokes have seperated engine and tranny oil. The tranny oil is in the tranny and the engine oil is in the fuel ;-)
Ford ATF is also an acceptable alternative.
For the next 150 hours or so I used Lucas Oil, Maxima,Motul, Bel Ray etc and have never heard that same chatter again. Yes I used the correct Rotella.
Now I just ordered a case of 12 Amsoil tranny oil and am excited to use that.
Personally, i would stick with motorex considering it is what KTM specifies... but that's just me..
Post a reply to: HP Trans Oil for my KTM 150sx ok?
