Reinholds, PA
11/1/2014 6:28am
http://www.ebay.com/itm/ACERBIS-Reticulated-Gas-Tank-Foam-CR-KX-RM-SX-X…
Has anyone ever used this does it work thanks Danny
Cheap, light ....
...and gravity fed, float-type carburetors don't give a shit what's going on inside the fuel tank. they are only concerned with what's going on inside the float bowl - which, not coincidentally, usually have "baffles" around the main/pilot pickup. ..and again, the sloshing in the fuel tank is at such a high frequency, the float bowl will never be starved for fuel.
...ironically though, if you put foam inside of your float bowl (because you are an idiot), it might take up just enough volume for the carburetor to starve for fuel. hahahah!
It broke down, and little foam particulates were all over inside my gas tank and clogged my fuel pump.
As far as it falling apart or dissolving and causing issues, I don't know, we changed it out about every 2-3 months.
It's definitely not just a gimmick.
Post a reply to: Gas Tank Foam ?
