Lehi, UT
5/31/2012 10:04pm
I tipped over in a corner and my front brake went out, never saw any fluid leaking anywhere.
Lever goes all the way to the grip with no compression.
I bought a "master cylinder replacement kit" and swapped all that out and bled all the air out and don't see any fluid leaking anywhere but still the same result, no compression. Help!
Pull the caliper off the wheel and compress the piston into the caliper. This will push fluid and the bubble up into the master cylinder. I would do this several times. If it still is not 100% squeeze the lever to the bar and hold it. Crack the banjo bolt that holds the line to the master cylinder....a little fluid will squirt out....then re-snug the banjo bolt. It is very common for air to get trapped in this area.
tighten them and rebleed the system and see if the compression comes back.
I may take it to a buddy that went to MMI to check it out if I can’t figure it out.
you need to compress that piston completely in the caliper (spread the pads). if you don't the air pocket behind it will never let you build pressure. i had this exact same thing happen to me last year.
let us know what your result is as now i'm curious. if you had other issues (leak) you would know. this has to be solution.
Still this happened after a hit, one might suspect some mechanical damage somewhere?
Cant say its a cure all for every brake bleeding dilemma, but its saved my ass on more than one occasion from having to actually pull out wrenches and do any real work.
Post a reply to: Front Brake problem 09 RMZ450 HELP!
