Can anyone help?
After too long out the saddle I’m looking at getting a enduro bike for green landing, then hopefully some enduros.
I raced MX at exert club level, but that was a long time ago so I’m after bike that’s not going to kill me, but also a bike that will enable me to at least compete, if after time I feel I can and want to race.
So far I’m thinking 2012 to 2016
Honda crf250x
Yamaha wr250
Any thoughts on what is the better bike?
Pros and cons of both?
Many thanks 👍
Honda crf250x
Yamaha wr250
Many thanks 👍
Just cost of ownership of a 2 stroke vrs 4stroke is one solid reason, your not dealing with valves, cams, cam chains, dual oil compartments....etc...
Ease of maintenance on a 2stroke it a lot less.
With a ktm you can get parts and accessories just about anywhere and usually in stock.
Other reasons, are weight and they don't overheat as easily.
If you decide to go for a 300 try to stay 2017 or newer, when ktm moved the starter below the engine and if you can find an xcw you can avoid linkage too.
I have a 2015 300 xcw, that has mx tec carts and a revalved shock, both ends prpoerly sprung, a slavens mule kit and a fww.
I love the bike, it's a tractor, I can lug it up greasy steep hills in 3rd...it will pull 3rd just about anywhere.
Power, suspension, handling are all fantastic, but I spent time setting it up the way I like it.
...and yeah, a top end needs to be done every 80-150 hours (depending on how you ride), and they take about an hour to do.
No adjusting or fiddling otherwise.
I'd aim for a 17+ KTM if you can afford it. Otherwise, I know a lot of people liked the closed cartridge forks on the 12 and 13s (maybe 14s?). The problem with the older ones is the e-start WILL break a lot. In my experience, any money saved on the 13-16s is made up in parts. 17+ FTW.
The cylnder head on the X is much more "dependable" than the R's (especailly in the later years as you've noted).
The chassis is excellent and SO EASY to tune (Showa spring fork). Aftermarket parts are readily available and super affordable.
Get a good clean used bike. Put a good battery in it. Jet it proper (Lots and lots of info on that. Go check the 250X section over at ThumperTalk)...and go ride those trails!
I raced them in Baja and in the dezerts of California, Nevada and Oregon. When the 2017 CRF450RX and Honda had their media-day, I grabbed their (Honda's) 250X that they had on the truck to scout out the trails at Cahuilla Creek. I was reminded how good that bike truly is. I even did some laps on the MX track and had a blast!
Good luck!
Depending on the type of offroad you will be riding:
Super tight single track, 3rd gear and below, I say any flavor of 2 stroke.
More open 2 track, gncc type, to anything you get above 3rd gear a 4 stroke will be better.
If you ride a mix of the above I would say a 250cc 4 stroke is a good all round bike. If dunes or high altitude are in the mix a 450 is nice to have, but they can tire you out trying to go fast in super tight terrain. Fuel injection is very nice to have, but on my carb 4 strokes I could get away with not changing jets on weekend trips from 1000ft home to 12,000ft. A 2 stroke will need rejetted at 6000ft or so.
I was leaning towards a 4 stroke as I used to race 2 stroke 250’s and always fancied a trying a 4/
My son races karts at a very high level so I’m upto speed on 2/ stroke running etc so will look at all options.
Can’t wait—- I’m in the U.K. so we just need some good weather 🤓🤓
i would recommend a 300 twostroke easier to ride at lower rpm
Feel free to thank me later.
By the way I’m in the Uk, plenty of sand tracks to ride even when the weather is bad.
Beta rr350 etc
I’m tempted to stay mainstream but a quick look at YouTube and written reviews looks pretty good
I’m not Ricky Carmichael 😁 so want something easy, fun and fast enough to wake me up
Thanks lots everyone 👏👏👍👍👏👏
https://www.biketechuk.co.uk/used-For_Sale_Beta_RR350_2016____460000_PR…
Post a reply to: Enduro bike help please
