ES
4/11/2019 5:08am
I was watching the 2018 Las Vegas Supercross, and in kawasaki's sience of supercross they said that Eli's cutch was getting changed every time he was riding, so this years kxf goes with hidraulic cutch can that be the problem? Eli uses the clutch so much, mabye new clutch doesn't fitted his way of ridding perfectly? I'm hopping that Eli's can charge through this last rounds as hard as he did it in Nashville
Check out the latest episode of Main Event Moto for more context
With the hydraulic clutch, he can't tell when it's going away, so the theory goes. I have no idea if that's true or not or if that explains anything about his inconsistencies this year (I tend to believe it is due to something else), but I've seen it discussed several times on here and it sounds plausible that perhaps some of his problems could come from the new clutch system.
honestly, it probably doesn't help. you lose a little bit of feedback with a hydro, so you get less sense of how hard you're beating on the clutch.
All of us have had arm pump and know what its like.
Hes on a new bike for 2019, and hes doing a hell of a lot better than the new bike in 2016.
2020 and 2021 should be business as usual.
Be all that as it may--this is about Eli and I just don't see him being a guy that's going to shift blame onto the equipment
Eli's problem is that he isn't ok with going fast unless he's in his comfort window. I feel the same, I can't push unless im comfortable in the conditions I'm riding.
Your last sentence is a bit contradictory--- you agree that Eli can't push unless he's in his comfort window, so why is it so hard to understand that a funny feeling clutch may be enough to get him outside that comfort window ??
Now , on the other hand , it may NOT be the clutch at all , I would guess that there are less than 5 people in the world that know what the real story is behind his inconsistency-- and I'm also guessing the NONE of those 5 post on Vital,lol
He needs another video form JS7 talking good about Eli, and the win in the next race is in the pocket
* He was vocal about the carbed yamaha. He was prooved right and he went back to factory again yamaha later
* Wasn't comfy on the '10 Kawi. Got off it then went back and got some factory help again later with 22 Motorsports
* Dont recall a bad thing being said about the suzuki the first time. Back on a factory bike now
* Didnt like the last generation of Honda, not sure if the bridge was officialyl burnt though.
Im just not seeing all the burnt bridges, everything comes back around it seems, atleast with Chad anyways
Post a reply to: Eli Tomac Problem Found
