Rancho Cucamonga, CA
5/14/2021 3:03pm
Wasn’t finding any answers in tech help so here I am. Has anyone successfully installed one on a 17-20 bike? I did one on my 11 and 15 and they never leaked again. I’ve tried to press one in three times on my 2017 and it’s still leaking.
I’ve wasted almost $100 in oil, coolant and parts at this point and I’m super frustrated. I even have the OEM Honda installer collar tool to do it. What am I missing? Thanks.
I know there’s a wizard or two lurking here that knows Honda engines better than anyone else.
Is the water pump bearing still in good shape?
Do you have the round plastic piece that came with seal?
If so, place over top of seal and thread impeller on shaft and turn til stops.
seal should lock in place, level w step on shaft
Was a You Tube- using washer and nut to set height of seal
I think there's a ceramic washer in these seals. They break if you look at them wrong when installing
I just did one, Yes a Honda...
Round black plastic disc looking piece comes with the seal
that sets the seal depth
there is a oem part number for the tool from honda service manual
this is aftermarket kit piece
2009+mechanical water pump seal replacement
Post a reply to: Crf450 mechanical water pump seal
