Sundsvall
SE
2/6/2022 12:16am
So, short story long.
About 10 years ago i decided to build a balls out cr125 build on my -02 chassis.
I made a HPP cylinder conversion, sent the engine to Eric Gorr, went for a big bore/stroker kit ported for mid-top and race fuel so it ended up being a 155cc engine.
Got it back, the cylinder was un ported and the engine had a 2mm squish gap…
I then went for another route, let another tuner correct the head and port the cylinder.
The problem is that the porting was corrected to the new 58.5mm stroke and the port floors were lowered 2mm to compensate for the 2mm further down that the piston goes at BDC with the stroker crank.
But when the port floors were lowered, the piston skirt ended up being to short and exposes the crankcase to pipe at TDC as you can see here.
After that i put the bike away since it performed really bad and bought a sx150 instead.
But now i have started to give the CR another chance and sent a -02 cylinder for a new 56mm bore and plating so with the 56/58,5mm bore/stroke combo it will be a true 144cc and using a cylinder spacer to raise the cylinder to compensate for the changed stroke.
So the thing i looking for now is some dyno graphs if some of you guys have tested different exhausts on the 00-03 engine and same with different intakes.
I currently own PC, FMF and Dep pipes as far as exhausts goes and Boyesen rad valve and stock intakes.
Just looking for every little bit of extra HP for this build. I have a programmable CDI and the 05-07 air boot before someone mention that.
I have went through pretty much every thread out there on both Vital and Thumper talk from the past 10-12 years, so now in looking for information that some might have but not have posted here before.
And no, i dont want to swap to a ktm engine or ”just buy a 250” since i own both of those to.
I built mine with a HPP, KX pipe and had Chad Watts work the carb, cdi, race gas, 07 air boot - and it was sill a dog.
As a wise person once said - “don’t go chasin’ waterfalls”.
In all seriousness, good luck. I gave up and sold mine when *I hit the realization it looked way better than *I was ever going to make it run. Hopefully you have better luck, and find the missing link, that it sounds like we were/are both searching for.
Back in -08 i found another of those team bikes for sale on the internet, the seller did not know what he had and i bought it cheap with really low hours on it.
That bike never ran as good as my first one i had in -02 so it was then i decided to do the 155cc build.
But even with the 155cc it did not run as good as my first 125. Now i have found some reasons for it, but if i could get the CR with full race prep and 144 or 155cc to run as a stock sx150 i would be more than happy.
Air Stryker carb
Rad valve
Swede tech exhaust manifold
FMF fatty and shorty combo
Up a tooth on the rear
My 2000 hauls my 190# ass around pretty well
Zero head or port work. Stock head, stock cylinder
My son has an 04 and we like my motor over his which has nearly the same set up but performs differently which I account to that stupid servo operated RC valve.
Or just keep dialing the ktm and live happily ever after.
I have bought exhaust flange spacers that i will try but i have yet to decide if i should buy swedetech, PC or the Boyesen exhaust flange.
I have also speaked to Hygge about letting him make a custom pipe for the engine as soon as it’s back togeather so i can give him the port timing and maps for it.
Other than that i am pretty sure that it is just a internet thing that people belive that a -95 HPP cylinder is better than the newer style.
At the dyno the HPP and newer style cylinders perform the same.
Sorry, not trying to be negative, but rather realistic and pragmatic. How much, is your time and sanity worth? The cr125 was slow 20 years ago, and probably wouldn't out perform a ktm85 today.
I am sure there are plenty of people will come here and say you need this crank case, that cylinder, this carb, this air boot and I am sorry but I don't think they are in reality or able to separate fantasy with objectivity.
here's the best mod I've done for my 2003 CR125R.
But it can be done, the 134cc that Leib ran at RBSR put out 38 on the dyno so i can’t see why 40hp out of a 144/155cc should be a problem.
Just trying to narrow down the parts list a little bit.
From there an extremely clean/ recently rebuilt/ well running engine, not some 28 hour clapped out special (what I had lol)
I found that a 100 rear tire made the bike feel noticeably faster than the 120 that was on the bike when I got it. Use a normal chain, not something with x or o ring that robs power. Basically limit everything that robs power before trying to make the CR125 engine a screamer IMO. Check to make sure the flywheel is the stock flywheel and not something heavier that a previous owner installed. Also dropping some weight on the riders part is almost always the most effective mod.
All those things is pretty obvious part from the Lectron carb that all the VET riders around the world praises but you never see one on a 125 race bike for some reason.
The thing is that after had my parts over the sea two times with a so-so result i wanted to try my luck here in Sweden this time.
I don’t doubt Morgans skill in any way, just want to be closer to the tuner this time.
What rod are you using for the long rod conversion?
Post a reply to: Cr125 00-03 best upgrade parts.
