- Pick trends
- Create a private league
- And more!
99/s1200_5A390892_189D_45C7_82B5_DAA12B3A7A9C.jpg" class="img-fluid" />
In 2016 & 17 I restored/rebuilt a 2004 YZ250 and I wanted to do a “tribute” to the late 80’s YZ I had all through that era. I was in the same predicament as you with the blue tank issue. I took the plunge and ordered up a white Clarke tank in the stock capacity. When it arrived I did note an ever so slight difference in the shade of white, but it was so close that it wasn’t a problem for me! I was building the bike to ride & race in vintage events and was happy with the product! The fit was the same as the stock tank, the purchase included a black gas cap and the petcock assembly bolted right up!
On final assembly at completion of the rebuild, I installed all the white plastic and retro YZ decals along with a red CEET seat cover and was 100% happy with the final result!
I never had any issues of any kind with the tank and based on my experience with this tank I would definitely buy another Clarke product if needed!
Good luck with your decision and I hope you’re decision results in a result as positive as mine was!
Keep us posted on your progress and post up a pic or two if/when you get your project completed! Cheers! RP
The issue you will have is the rubber tank pads on the frame. Tank was designed for the steel frame so it rubbed this on spot on the frame.
One spot on the rubber tank pad does it matter. No but it does happen a little bit. Doesn't affect anything structural or visually. The stock gas cap works on it fine. Ran them for 14 years no problem.
This is my 06 when I sold it last year.
Based on the above reply, I'll just try running a stocker. Didn't think the threads were right, but apparently I'm wrong.
I wouldn't be afraid to order something from them, they've been in the tank game a LONG time.
Doesn't mean anything but ...
Post a reply to: Clarke fuel tanks
