Chad Reed Bike Problem at Tampa??
KDXGarage
AL US
Edited Date/Time 2/27/2018 1:38am
Hi. Did anyone read about any further details on what exactly went wrong on Chad Reed's bike at Tampa?
Thanks.
kongols
Riga LV
2/26/2018 1:58am
My guess would be- mission accomplished.
pmshortt2
VA US
2/26/2018 3:03am
Thanks.
The new Huskys have lots of electrical issues to the point that they shouldn’t even be selling them the way they are. 3 people at my local track have all had horrible wiring problems costing them motos and money. Each had to get new wiring harness’...
Marcello10
Parma IT
2/26/2018 3:38am
He said his bike kept cutting off, one time even before one of the big jumps. Too risky to ride it so he decided to pull off
kb228
Mansfield, OH US
2/26/2018 4:15am
Problem is its a husky
Zycki11
Ankeny, IA US
2/26/2018 6:25am
Heeer Yeee, get that logic out of here!
HD1200
Greenville, GA US
2/26/2018 6:26am
Actually he said 3 times but the first thought did it really just do that.
aees
2/26/2018 7:06am
You should silicone all open ends of cables, and also add some sillikone where they disappear in to the components. Do that and use shrinking tape and you are good to go.
KennyT
Vista, CA US
233rd
2/26/2018 7:39am
It was a shame he had mechanicals. There was a good chance for a top ten finish
mx317
TN US
2/26/2018 7:43am
I guess that is points leader Anderson's problem also.Whistling
b_kowalsk
Thomaston, CT US
2/26/2018 7:46am
Honda should bring Chad on board.... Then he'll have a factory ecu and no more electrical issues.
2/26/2018 8:08am
aees wrote:
You should silicone all open ends of cables, and also add some sillikone where they disappear in to the components. Do that and use shrinking tape...
You'd think that Goose would know stuff like that. Wink
p0wn
Portland, OR US
2/26/2018 10:30am
pmshortt2 wrote:
The new Huskys have lots of electrical issues to the point that they shouldn’t even be selling them the way they are. 3 people at my...
I've had this experience with new KTM's and Huskys. This last year friends and I have bought 5-6 of em and all had different electrical issues. If you look at the wiring it's super shitty and not weather proofed at all. The connectors are dirt cheap. Within a summer my wiring had all corroded at the connectors. Pretty sad.
aees
2/26/2018 10:46am
Note was more for us regular riders. I assume they replaced the wiring with factory stuff, or make their own. KTM used to have a "airline grade" cable-package as Powerparts, but dont anymore.
Could be anything of course. Most problem came from old way of mounting the capacitor which has been corrected since late 2016 and 2017. But, again, to be sure wires does not brake take 10min and some silicone. Dont have to remove cabling for that. Seat and just lifting the fuel tank some + behind number plate and you are good.
If you have not done it when it was new, you need to cut open all the plastic wrappers and drain them from mud, gravel and water.
BobPA
PA US
2/26/2018 10:53am
p0wn wrote:
I've had this experience with new KTM's and Huskys. This last year friends and I have bought 5-6 of em and all had different electrical issues...
What are you guys doing to your bikes? No issues from any bikes for my riding crew. Have not seen and electrical problem from the Japanese or the Austrian bikes in quite some time.
Lurk Ing
2/26/2018 11:24am
BobPA wrote:
What are you guys doing to your bikes? No issues from any bikes for my riding crew. Have not seen and electrical problem from the Japanese...
Big difference with bikes that actually get ridden and washed. Even on bikes with a premium
aees
2/26/2018 11:37am
In my experience these problem comes when people wash of their bikes, and dont use air compressor to remove water and moisture. Also gets worse if you put the bike in a non-humidity controlled area, specially if you dont remove excessive water and moisture.
Same thing that kills linkage and svingarm bearings.
Since i started doing this, i run 80h easilly in 6 months on my bearing. And we are talking about me that rides in rain, sand tracks etc so bike gets washed after every 1h.
seth505
SD, CA US
1271st
2/26/2018 11:38am
Ah, the ol "if you have a KTM/Husky then you don't ride" argument. Real brain surgeons in here per usual.
mattyhamz2
So Cal, CA US
846th
2/26/2018 11:43am
A buddy of mine just took his bike to Ktm last week so they could replace the entire wiring harness for him because he was having electrical issues.
RCMXracing
N., TX US
2/26/2018 11:46am
Disagree on the “dirt cheap” connectors. The connectors are marine grade, what they use out on the good ol’ high seas. I will agree that the wiring could use some tidying up, prevent chaffing points.
rikhek
Tulsa, OK US
2/26/2018 12:05pm
I love it when the biggest prick on track has issues. Cock sucker deserves everything that happens to him. Karma is a bitch.
kiwifan
2/26/2018 12:08pm
Nothing wrong with Husky's !!!
captmoto
Rancho Cucamonga, CA US
2/26/2018 12:13pm
OCD pressure washing? I have only removed my seat and side panels once to clean my bike. I pull the panels after I wash the rest of the bike to hand wash if needed. You know all the big time riders pressure wash after every practice and heat and probably again if they have to ride the LCQ and then before the main. While my Husky is low hours I've had no problems electric or otherwise with mine.
Asimo
2/26/2018 12:13pm
Haven't had an electrical issue since the days of points.
gerg
2/26/2018 1:53pm
Awwwww sure we can't turn that frown upside down?
Racer111
Concord, NC US
2/26/2018 2:17pm
Exactly why I will never own either of those pieces of shit.
Post a reply to: Chad Reed Bike Problem at Tampa??
