Anchorage, AK
6/3/2016 3:22pm
Recently, a vent hose fixture broke off on the carburetor of my 2014 Husky TC 250. I tried a custom fix but it didn't work. I don't want any dirt getting into the carb. What should I do here? Can I JB weld the hole shut or is that a bad idea? Does anyone know what part of the carb this vent hole is relevent to? I don't want to have to buy a new carb if I don't have to, but the current situation is preventing me from riding.
EDIT: Please disregard all the dirt, this is an old picture before I cleaned it, it's no longer there. But the hole is. Left side of bike next to the choke.
http://www.ebay.com/itm/Hose-ID-1-4-Barb-x-1-16-Male-NPT-Water-Fuel-Oil…
Plus, the picture shows the thread area being much wider than the barb area, even though the barb area is supposed to be a 1/4 inch and the thread area only 1/16 of an inch. Is the picture not to scale?
As a 21 year old man I shouldn't be this confused, but I am.
2) Wash the bike thoroghly and remove the carb or rotate it out to the side so you can access the top vent-tube nipple.
3) Remove the upper vent tube hose and the rubber plug from step 1.
4) Coat the outside of a piece of your brass tubing in some JB-Weld (or other epoxy).
5) Slide the tube down through the upper nipple far enough that it blocks off the hole where the broken nipple used to be. Pack a little epoxy into that broken hole for a good seal. Then let the epoxy cure.
6) Find yourself a plastic tee fitting and install it in the upper vent tube.
Back in the day the carbs didn't have a vent tube with a drain. If fuel splashed up in the vent tubes, it could cause the bike to bog. Most racers installed plastic Tee fittings above the carb to allow fuel to drain out of the vent hose.
Eventually the manufacturers re-tooled the carburetor casting dies and included the Tee-fitting in the carb body. The lower the drain portion of the Tee is, the better it works, but you still have the vent on the other side too, so it shouldn't cause you a problem.
1/16" is not the thread diameter, it is 1/16" Pipe Thread (NPT). Nominal pipe size is based on a measure of the ID of the pipe, so in reality, a 1/16" NPT has an outside thread diameter of 0.313 inch, there isn't enough material in the casting to drill and thread a hole that large.
Another option if you want to use the stock location is to press-fit a nipple in that hole.
Take a look at the brass overflow drain nipple on most Japanese carb float-bowls... They are brass tubes like you had in your other thread that have been press fit into a precisely drilled under-sized hole.
To do that you'll need to measure the exact diameter of your brass tubing and find a drill bit that is about .010" to .005" smaller than the tubing to drill out that hole. Then you can cut a piece of tubing, chamfer the edge and drive it in with a piloted-punch tool.
That's an awesome solution to have in your "back pocket"... I've never broken a carb like that, but I'll save that part number in case it happens.
If you do have to drill it out, make sure you drill it undersize. A little drip of red loc-tite can help if you aren't confident with the press-fit.
Besides I rarely open my handbook anymore, I need to shake the cobwebs off it
https://www.dicksracing.com/motorcycle_performance/4-stroke
The one on the right is 2.5 mm.
Anybody have a suggestion on how to drill this?
I had access to many carbs/barbs/90 degree barbs to find the right fitting barb, that was key in finding the proper fit.
I destroyed a couple old carb bodies removing barbs to test in the hole, once I found one I was happy with I stripped the broken carb and heated the hole with a mini torch, I then lightly pressed in my new/used barb.
I couldn't thread the hole because the material was to thin.
Understand i had to search for the right fitting piece, if you do not have access to some brass tubing from old carbs this fix will be hard, every brass tube looks like it will fit, but it has to be he perfect size to really be fixed for good.
Before I had the proper brass piece I went through 4 wrong ones.
Hate to say it but if you can find a used carb for super cheap it is the best fix, because I have done this fix and time vs finding the right barb made this repair a loser for me. I did help a customer, but it cost me money to save him money.
If you try to thread the hole I would go to 3mm and get one of these.
http://www.amazon.com/Male-Thread-Pneumatic-Tube-Fittings/dp/B00880BBPW
http://www.ebay.com/itm/Yamaha-RD-Oil-Injection-Nozzle-RD350-RD400-RD25…
Post a reply to: Carb experts, I need your help..
