Carb Question
12/28/2017 9:00 AM
Ive got a 98 yz250. I just bought a carb for a 99 yz250 for it. For anyone that has put the newer carbs on the older bikes, what did you do with the tps wires? Did you cut it? Zip ty it? Let it just hang off of the carb?
2017 RMZ450
2005 YZ250-sold :,(
1998 YZ250
2005 KX250F
Thanks to : Factory Effex, Simi Valley Cycles, N2Dirt, Acerbis, DT1, Fasthouse, Matix, FMF, Mika Metals
12/28/2017 10:00 AM
A local shop pulled the connecting plug out of the carb and filled the space with epoxy. Done deal.
12/28/2017 11:01 AM
Thanks frodad!
2017 RMZ450
2005 YZ250-sold :,(
1998 YZ250
2005 KX250F
12/28/2017 1:10 PM
No problem! Good luck with the 99, I have a 04 that I just put back together, can't wait to rip it.
12/28/2017 1:24 PM
I think I just taped mine to the rest of the wiring loom
12/28/2017 1:42 PM
Thanks! This is the last piece of the puzzle. Swapped the forks and clamps for newer stuff! New fmf pipe. We just couldn't get it to run right no matter what we did. So this last weekend I decided to take the carb off our 2005 kx250 and try it out. Sure enough that was the problem and the bike ran awesome! So if all goes well, I'll be riding it this weekend for the first time
2017 RMZ450
2005 YZ250-sold :,(
1998 YZ250
2005 KX250F
12/28/2017 2:39 PM
Thanks
2017 RMZ450
2005 YZ250-sold :,(
1998 YZ250
2005 KX250F
12/28/2017 4:10 PM
mattyhamz2 wrote:
Thanks! This is the last piece of the puzzle. Swapped the forks and clamps for newer stuff! New fmf pipe. We just couldn't get ...more
A lot of times the only way to get those older carbs working right is to replace or reseal the body and slide.
12/28/2017 6:04 PM
I personally wouldn't do anything irreversible like plug holes with epoxy just on the off chance you end up wanting to use the carb on a newer YZ250 or sell it to someone who does. As stated above, just tape the wires or seal them in a way where water can't get in them.
Bear in mind, the power jet is "normal-open" when it is not energized. That means it will never close and it will richen your jetting if the wires are not connected. The easiest way to address this is to replace the power jet with a small allen set screw that will thread in its place and plug the circuit. Remove the power jet from the carb and take it to Home Depot to compare. They have a selection with different thread pitches and lengths.
Powerband in every gear !
12/28/2017 6:05 PM
FGR01 wrote:
I personally wouldn't do anything irreversible like plug holes with epoxy just on the off chance you end up wanting to use the ...more
Thanks man
2017 RMZ450
2005 YZ250-sold :,(
1998 YZ250
2005 KX250F
12/28/2017 9:28 PM
Let us know how she rides!
12/28/2017 9:40 PM
I will for sure! It’s been 3 years in the making. And it’s been a loooooong 3 years
2017 RMZ450
2005 YZ250-sold :,(
1998 YZ250
2005 KX250F
