8/20/2020 5:40pm
Hi just looking for if there are any forks or products that support External High Speed Compression Dampening in forks. Kreft and Krooztune look like good options said below. "just looking for external mid valve control (high speed) so i can have constant and consistent dampening through the whole stroke. low speed dampening mixed with the right oil level controls the low speed stuff and spring rate controls the suspension its self and how the bike holds up under braking and weight transfer. if i could control the mid i could find a setting fr the small slow bumps with low speed or normal dampening then use the mid valve (high speed) to find the high speed setting for big bumps then just have a normal bottom out stack inside the fork since that's a very stiff setting its more for crazy situations so i don't need to control that."
Yeah i have a set only problem is they are high and low speed rebound not compression
Post a reply to: Any suspension products like forks and cartridges with External High Speed Compression Dampening?
